Tons of crashes
Posted: Sat May 23, 2020 11:17 am
by CCIDgfx
I'm getting a ton of crashes today. Octane log attached.
C4D R20
Octane 2020.1-R5
Re: Tons of crashes
Posted: Mon May 25, 2020 8:35 am
by bepeg4d
you are having CUDA 700 error, that in general is related to corrupted or outdated Nvidia driver.
Please download and run GPU-Z:
https://www.techpowerup.com/gpuz/
And share a screenshot from the Graphics Card tab, for all the available Nvidia GPUs, thanks:
ciao Beppe
Re: Tons of crashes
Posted: Mon Jun 01, 2020 11:47 am
by hemul355
I have same problem with all of 2020 releases, up to R6.
C4D R21.207
There is no such problem in the 2019 release. I'm desperate. I have to use 2019 now, but I do not like this situation.
Re: Tons of crashes
Posted: Mon Jun 01, 2020 2:43 pm
by aoktar
tons of crash means that, something wrong on your side
- improper setups for octane, maybe unstable driver/gpu for current version of octane or unsufficient gpu
- you hit a bug in the renderer
- low amount of resources for the Octane, always close other softwares which uses gpu vram in this case
Re: Tons of crashes
Posted: Mon Jun 01, 2020 3:06 pm
by hemul355
Sorry, but i don't understand you. I wrote "There is no such problem in the 2019 release" and I meant than I had SAME setups for octane, SAME driver/gpu, SAME scene, SAME amount of resources for the Octane and others — ALL THE SAME ON THE SAME COMP! I just change folder with Octane in Cinema Plugins folder and got the problem.
Re: Tons of crashes
Posted: Mon Jun 01, 2020 3:38 pm
by aoktar
hemul355 wrote:Sorry, but i don't understand you. I wrote "There is no such problem in the 2019 release" and I meant than I had SAME setups for octane, SAME driver/gpu, SAME scene, SAME amount of resources for the Octane and others — ALL THE SAME ON THE SAME COMP! I just change folder with Octane in Cinema Plugins folder and got the problem.
Same setup, same plugin core but different Octane version. 2020 has new features and changes, this doesn't mean your setup well for 2020. There maybe different functionalities and not good for new drivers or spends more resources.
Re: Tons of crashes
Posted: Sat Aug 22, 2020 4:02 pm
by Quakz
Hey hemul355, Hey aoktar,
did you find any solutions. Ihave also crashes all the time. I have enough free vram, i changed drivers (451.48,451.77,452.06).
I made a clean uninstall of drivers and changed the cuda-timeout to 60 sec....
What have you done? Stayed with the 2019-Version?
Best regards
Daniel
