Problem with instances
Posted: Fri May 15, 2020 5:38 am
by promity
From time to time, I encounter such a problem as the lack of objects in IPR, while they are visible when rendering on F9.
Out-of-core has setting up to maximum RAM. LW 2019.1.4, Octane 2019.1.5.1
Re: Problem with instances
Posted: Fri May 15, 2020 8:53 am
by juanjgon
I've seen this problem before, but unfortunately, I've never been able to reproduce it. Usually, if you reload the scene from the IPR all works fine. Have you tried that?
Posted: Fri May 15, 2020 9:08 am
by promity
Ok, the files was sent.
P.S. I found that if I remove the Ocean Tool Kit from Nodal Displacement, then the IPR displays the scene normally.
