2020.1 / 21.7 - Octane tag issues
Posted: Sat May 02, 2020 9:32 pm
I have two (small) issues with the Octane file tags:
1. When there's a dot in the tag, the dot and anything after it will be removed in the final filename. Of course you can just not use a dot, but sometimes a dot is preferred over other separators. (Dots work fine when used in the Output path) 2. The "postfix" becomes a prefix in the layer/pass names in the EXR file. (Side note: It would be nice with the option to not include the filename in the layer/pass names [they can become pretty long and the "pass id", the most interesting info, comes at the end, and might be hidden by the editor], it would also be nice to have the option to not include the frame [when you're just rendering stills] in the file name and/or pass name)
