Page 1 of 2
Sun position navigation via rotate gizmo?
Posted: Sat Apr 11, 2020 6:44 pm
by Greggers
Hi guys, is there a way to navigate the position of the octane daylight sun position via a rotation gizmo? I use this method in Cinema 4d so it would be great to be able to do it in blender.
Re: Sun position navigation via rotate gizmo?
Posted: Sat Apr 11, 2020 10:29 pm
by J.C
It is possible using ball gizmo:
Posted: Sat Apr 11, 2020 11:12 pm
by Greggers
ah yes but is there a way to have a transform gizmo in the viewpoint control the sun and sky rotation?
Posted: Sun Apr 12, 2020 2:04 am
by grimm
Add a 2D or 3D transform node to your HDRI Image Tex node. The X and Y translation fields will rotate the HDRI in the x or y direction.
Posted: Sun Apr 12, 2020 8:43 am
by Greggers
In cinema I can use a transform gizmo in the viewport to adjust the sun position. Trying to get blender to match the ease of cinema 4d as much as possible for speed. If I had to go into the node editor is a path I would only use for maybe more precision. I should have added I wanted a transform gizmo controlling the direction (rotation) in the ‘viewport’ in my first post.
Posted: Mon Apr 13, 2020 10:36 am
by linograndiotoy
grimm wrote:Add a 2D or 3D transform node to your HDRI Image Tex node. The X and Y translation fields will rotate the HDRI in the x or y direction.
It will rotate the HDRI, not the Daylight sun.
Next build will offer an Object Transformation node that right now is not compatible with the Sun Direction input. Being able to control the Sun direction using an object or a light in the scene is a feature I've asked for already, even if not a priority right now.
Posted: Mon Apr 13, 2020 12:51 pm
by Greggers
Thanks for the reply.
Posted: Tue Apr 14, 2020 8:27 am
by linograndiotoy
Sure!
Posted: Tue Aug 30, 2022 2:01 pm
by Tharso
did anyone find the solution? I would like to control the sun in the viewport like blender sun
Posted: Thu Sep 01, 2022 2:31 pm
by Tharso
is this already possible?
