Bug about PhoenixFD particle?
Posted: Tue Feb 18, 2020 11:55 pm
by HRHBG
I import foam Particle made by PhoenixFD and I use octane rendering it.
The color of foam is changing every frame. Is it a bug?
Re: Bug about PhoenixFD particle?
Posted: Wed Feb 19, 2020 9:38 am
by ChrisHekman
Could you share your foam particle with me? You can email it to
[email protected]
Posted: Wed Feb 19, 2020 8:27 pm
by HRHBG
ChrisHekman wrote:Could you share your foam particle with me? You can email it to
[email protected]
I can not email it because the size of the particle is large with 4GB. I can only upload some pictures.
There should be a certain probability that the foam that was originally white will turn yellow.
Posted: Thu Feb 20, 2020 1:29 pm
by ChrisHekman
Im sorry, but im not sure what I am looking at here. I assume these are both octane renders of two different frames of the foam?
But im failing to see any yellow, or meaninfull difference between the two pictures?|
Do you mean this part turning more white? That looks like it just became more "foamy" and there is more refraction going on between individual droplets of water?
- WhiteFoam.png (133.13 KiB) Viewed 5649 times
Posted: Thu Feb 20, 2020 1:34 pm
by HRHBG
ChrisHekman wrote:Im sorry, but im not sure what I am looking at here. I assume these are both octane renders of two different frames of the foam?
White is what I want, but sometimes it turns yellow.
Posted: Thu Feb 20, 2020 3:46 pm
by ChrisHekman
HRHBG wrote:ChrisHekman wrote:Im sorry, but im not sure what I am looking at here. I assume these are both octane renders of two different frames of the foam?
That makes sense. But I just do not have enough information here to figure out what is happening here.
Maybe show me a picture of the yellow render? Maybe show me your material? Would it be possible for you to create a smaller example of the issue and send it to me?
Posted: Thu Feb 20, 2020 9:58 pm
by HRHBG
ChrisHekman wrote:HRHBG wrote:ChrisHekman wrote:Im sorry, but im not sure what I am looking at here. I assume these are both octane renders of two different frames of the foam?
This error occurs when using batch rendering. Everything is normal during preview. Only the color of the foam will continuously change during batch rendering.
When rendering is wrong, the foam behind the cart turns blue.
I will try to send a smaller project to your mailbox and I guess the reason is that RTX acceleration is turned on.
