OctaneRender™ for Blender 2020.1.XB1 - 21.0 [OBSOLETE]
Posted: Thu Dec 26, 2019 11:46 pm
OctaneRender™ for Blender plugin. Windows and Linux versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production. Mac OSX versions are still a work in progress
NEW FEATURES SINCE LAST RELEASE
FIXES SINCE LAST RELEASE
You can read about new features of OctaneRender™ 2020.1.XB1 here:
viewtopic.php?f=33&t=73237
The installation consists from two parts:
1. OctaneRender™ Server
2. Blender - OctaneRender™ edition
After the server is run - you can start rendering (or open a rendered view) from inside Blender.
Windows
Blender Octane Edition - 21.0 (2.81)
Octane Server - Enterprise Edition - 21.0
Linux
Installation:
- Just run the installer to see its command line keys.
- If you need to run OctaneServer - run it as daemon:
DOWNLOAD
Blender Octane Edition - 21.0 (2.81) Linux
Octane Server - Enterprise Edition - 21.0 Linux
Please note, in regards to Bug Reporting:
- Bug Reports in this section refer to plugin-specific bugs only. Bugs originating from the Octane Standalone should be reported to the Standalone Forum section instead
- For faster troubleshooting, please provide as much information as possible. Please include:
- Please bear in mind - we are primarily an English-Language Forum. Please do not take offense if we request further clarification due to language differences.
- Upgraded to 2.81a
- Integrated 2020.1
- Supported octane sphere light("Property-Light-Sphere")
- Supported octane quad light("Property-Light-Area-Square/Rectangle")
- Supported hair material
- Supported randomwalk medium
- Implemented sphere attributes("Property-Object Data-Octane properties-Sphere Attributes", shown in the figure below)
- Supported OSL LiveDB
- Enhanced the OpenVDB feature
- Added missing options(velocity scale, velocity grid type, motion blur...)
- Supported to customize absorption/scatter/emission/velocity grid id as SA
- Fixed VDB volume renders as black box(SDF type) issue
- Supported to save cryptomatte passes as 18.x
- Fixed the brighter image issue when both "alpha channel" and "keep environment" are ticked
- Supported local view mode for OctaneBlender
- Disabled alpha in universal material Transmission by default
- Fixed the crash issue when exporting scene with motion blur
- Fixed the tile image resolving errors
- Tried to activate a license when accessing LiveDB
- Fixed obj import failure
- Updated the bug report link
Windows
Linux
Installation:
$ OctaneServer &Blender Octane Edition - 21.0 (2.81) Linux
- Your Hardware specifications (unless they are included in your signature)
- A clear description of the issue you have found
- Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots. If possible, files for testing would also be appreciated).
- Whenever possible, please confirm that this issue is only happening in the plugin, and not also in the Standalone Edition (if the bug occurs in both, it is likely that this issue should be reported in the OctaneRender Standalone section of the Forums).
