OctaneRender 2020 for Rhino (OBSOLETE)
v-cube
face_off wrote:
It (somehow) works now but I had to lower the environment / sunlight to almost 0 before the rhino lights came to life...
Maybe we can have a kind of global multiplier for the lights ?
Are you able to send me your scene please?
I sent you a PM..
Andy
1 x 4090 GTX, 1 x 3090 GTX
http://www.v-cube.de
Blum-Architekten
I`ve been working on this model since 1 year in the design process of this house.
Currently I was working on the lighting concept and therefor implementing several lights.
Suddenly I get
“Cuda Error Loading Scene : Tried to access pin via an invalid index 19
Tried to access null node pin”
Invalid index 19 – 28
Or
It can´t load a certain element and the program crashes.
Especially the orbx blocks don´t work. I have a light emitting VDB in the scene and a pretty big fur carpet, but even if I leave them off, the render doesn’t show the other orbx like trees.
A solution would be very much appreciated. I`m fighting with this already far too long.
A few weeks ago, I updated the NVidia driver. Could this be the cause?
I have GeForce Experience installed and updated to Nvidia studio driver 456.38.
Windows 10 64bit, 1 x GeForce GTX 1080, 1 x GeForce RTX 2080 Ti, 64 GB Ram, i7-6900K 8 Core CPU
Hi - this is almost identical to the another reported problem here in the forum, and I have an idea what is causing the issue.. I am working on a solution now.
I have updated the installers at the top of this thread with:
2020.1.5.123
- Fixed crash introduced in release 20201.5.122 when rendering block instances
Blum-Architekten
Thanks a lot Paul!
The new release solved the problem.
Cupcake1001
When will OR plugin for Rhino 7 be available, Paul?
Thanks!
Cupcake1001 wrote:When will OR plugin for Rhino 7 be available, Paul?
Thanks!
The last time I checked, the Rhino6 plugin also worked in Rhino7. Is this now not the case?
Refracty
Hello Paul,
I was trying to render a simpel mix material but the texture placement (planar mapping via Rhino) was not transfering to Octane Render (I used a Grayscale Texture in the amount slot of the mix material).
I used the recent O4Rhino plugin with Rhino 6 and 7. I also tested the old Plugin-Version 4.05 and tried the same thing, where it worked.
Can it be that the Rhino Texture Placements are not transferred to the Octane Engine.
Thank you and a good start into the New Year!
Nando
(System: Windows 10, Enterprise subscr.)
Refracty
Is somebody else experiencing problems with the texture-placement transfer from Rhino to Octane during rendering?
Refracty wrote:Hello Paul,
Nando
Can you please provide a sample scene which demonstrates this problem?
Return to “Rhinoceros 3D”
