OctaneRender 2020 for Rhino (OBSOLETE)
I have updated the installer at the top of this thread with:
2020.1.0.119
- Compiled with Octane 2020.1 RC2
roy_orengo
Hi Paul,
the new installer work.
Anyway, I've imported a material made by the Octane Studio 2020 with the new procedural textures and I can't see them inside Rhino plugin.
Neither if I enter in the LIVE DB from the Rhino plugin I can see these great and useful textures.
Roy
roy_orengo wrote:Hi Paul,
Roy
Hi Roy. Please see answer 9) in the Solution to Common Problems section at the top of this thread.
roy_orengo
Hi Paul,
I need to copy and paste only one new procedural texture at a time, or rhino crash here (I mean if I copy and paste the entire material).
Anyway, I can work well for now.
Thank you,
Roy
Can you give me the exact steps you are taking to get this crash please, and I will try to reproduce it and fix the problem.
I have updated the installers at the top of this thread with:
2020.1.0.120
- Compiled with Octane 2020.1 RC3
- Mesh items which have Live Geometry ON, but are NOT Block Instances or Block Definitions will now have A_USER_INSTANCE_IDS set to a non -1 value, so the Instance Range texture can now be used on these items
- Fix slow scene loading speed introduced in 2019.1.0.112 with the introduction of Clipping Plane support
2020.1.0.121
Almfeldt
Hello!
So fun to see all news etc, but how should i use them?
It doesn’t matter if you implement a hair node in the material if you don’t update the manual at the same time.
The Manual hasn’t bin updated since version 4. If i were i C4d user it wouldn’t be a problem cause you can find so much tutorials etc.
But for a Rhino user its harder.
So please explain how i should use the program, i simply don’t have the time to find out what every single change does and how i should use it.
But thanks for a great program that i probably only use 20% of it´s potential cause you guys are really bad on explaining your product.
Asus X99-E Ws, Intel Core i7 5930, 64 Gb Corsair Dominator ddr4 2132, 4 x Gtx 1080Ti Asus Turbo Watercooled
Almfeldt wrote:Hello!
Hi. You can refer to the following posts for the new features introduced in each of the major releases of Octane.
Octane 2018.1 - viewtopic.php?f=24&t=70809
Octane 2019.1 - viewtopic.php?f=24&t=72584
Octane 2020.1 - viewtopic.php?f=24&t=74586
The release notes in the OctaneRender for Rhino posts detail which of the Octane Standalone features have been implemented.
2020.1.4.122
- Compiled with Octane 2020.1.4
- Experimental support for the Octane Quad, Sphere Lights. Go into the Setting windows and enable the Convert Rhino Lights checkbox. Mouse-over this setting for details.
- Octane node "Groups" are now displayed in the Settings and Material tree.
- Added the OctaneLoadBackgroundImage and OctaneClearBackgroundImage command (this is untested at this stage)
Return to “Rhinoceros 3D”
