Recurring Plugin Crashes on Render
Posted: Wed Dec 11, 2019 6:41 am
by Adept
I have been trying to render a scene that is generally small, but has a large number of plant instances scattered using the Octane scatter obj. When I hit render, it goes fine for about 4-5 frames, then crashes, giving me the attached bug report. Anyone have any ideas? I can't decode what the bugreport says, so if any Octane gurus have some insight that'd be great. I suspect it's memory, but I've rendered much larger scenes no problem.
System info:
16GB RAM
Intel i7 6700k
GTX 1070 (8GB)
GTX 1060 (6GB)
In the Octane settings I have both GPU's set for denoiser, allotted 14.5GB/16GB RAM, and left ~150MB GPU headroom. Kernel settings are the same as what I use on most projects and what has worked in the past.
Re: Recurring Plugin Crashes on Render
Posted: Wed Dec 11, 2019 8:26 am
by bepeg4d
Please, try to perform a clean installation of 431.86 Nvidia Studio driver:
https://www.nvidia.com/download/driverR ... 1050/en-us
or 441.28 Nvidia Studio driver:
https://www.nvidia.com/download/driverR ... 4342/en-us
To perform a clean installation, please follow these steps:
And enable Denoiser only on 1070.
ciao Beppe
Posted: Wed Dec 11, 2019 9:00 am
by aoktar
I don't see crash on octane.dll and seems like a crash on plugin level.
You have 16gb ram and you may be on out of memory. What's total triangle count for scene and objects?
Posted: Wed Dec 11, 2019 9:06 am
by bepeg4d
please, open the scene, then go to c4doctane Settings/Others tab, and, at the bottom of the panel, enable all the Log option checkboxes:
Then, load the scene in Live View, then in Picture Viewer until crash, and share the c4doctanelog.txt file that you find in c4doctane directory, or in the path specified in Settings/Others panel, thanks.
ciao Beppe
Posted: Wed Dec 11, 2019 10:12 pm
by Adept
aoktar wrote:I don't see crash on octane.dll and seems like a crash on plugin level.
Poly count for the scene is about 2M, and about 2000 objects.
Posted: Thu Dec 12, 2019 6:23 am
by Adept
bepeg4d wrote:Hi,
ciao Beppe
Alright, I did that (after doing clean install of graphics drivers). Got a few more frames before crash, but it still crashed. It is a memory issue as I thought, and it says something about "render" vs "editor" subdivisions, but in all of my forester objects both parameters are equal. Any thoughts?
Posted: Thu Dec 12, 2019 8:26 am
by bepeg4d
please, try to render the scene at half resolòution.
You have only 16GB of RAM, and seems that they are not enough for that scene/resolution.
ciao Beppe
