Good! Next build will store the UI configuration correctly, so this should be solved.amandas wrote:That does the trick. Snapping to any border makes the main menu bar reappear.linograndiotoy wrote:Thanks!amandas wrote:This is the default view (deleted imgui.ini). Also, I will help you with debbuging this: when I changed taskbar settings to Auto Hide in Desktop Mode, suddenly the main menu bar appeared. I am guessing here this might be aspect ratio related. When I quit app and restart, the main menu bar is missing again (it reappears when I change taskabar settings).
Can you please try to press the Windows key+Left Arrow (to snap selected window to the left or right half of the screen) and see if you can see the menu bar?
Best!
Thanks!
