Adjusting surface parameters globally
Posted: Fri Nov 08, 2019 9:56 am
I have multiple surfaces using the same parameters and would like to make a setup where I can affect the brightness input of an Octane ColorCorrect Node inside multiple surfaces at once.
I attached an Octane Float Texture to the parameter on two surfaces and added envelopes to those.
Problem is, when changing the value of those envelopes in the Graph Editor, only one surface changes in IPR - even if I single select the other one, I can't affect it to make it change in IPR. Only once I go into the surface Node Editor for that surface will IPR discover that the value has changed. I have to enter the Node Editor for each surface before the change is refreshed (making the whole system pointless) - (EDIT: or framestep to make it catch the changes).
Is this a bug, a LW limitation? Is there a way around it - to control surface parameters globally? (LW 2015.3)
