Triplanar mapping not working
Posted: Wed Oct 09, 2019 4:33 pm
				Hello all,
I've received an .obj file from a client, and I can't get to make Triplanar mapping working in Octane.
As you can see in the scene, I have created a material with a checker texture, a triplanar node and a texture projection node set to triplanar as usual. It works on the basic primitives and on the figure but nothing happens on the object... I've tried scaling it's UV's, remaking them by reprojecting them, nothing works. Otherwise UV, Cubic or any mapping type works well (see second pic), but Triplanar stays blank.
Has anyone encountered this situation or have any idea about what the problem could be ?
Note that the object is weirdly meshed with triangles like it often happens with .obj exports from client files, could that be the problem ?
Thank you in advance for your help !
