OctaneRender 2019 for Inventor [OBSOLETE]
Posted: Thu Oct 03, 2019 2:07 am
by face_off
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Inventor - TEST and STABLE releases.
Inventor Version
The plugin requires Inventor 2018-2020, Windows 64bit.
License upgrade
Unless you have a subscription license, you will have to upgrade your version 3 licenses to version 4. This upgrade is free and can be done via these 4 steps: To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 387 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Network Rendering
For Network Rendering, you must use the Octane slave release from the Octane Standalone installer which matches the exact Octane version of the plugin you are using. This version matches OctaneRender Standalone 4.00.
Support Issues
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Nvidia driver version
- Inventor version and build number
- OctaneRender for Inventor version (ie. 1.20.1.10)
For more information
- Check the specific Octane 2.0 features in this plugin at http://render.otoy.com/manuals/Inventor/?page_id=563
- Read the on-line manual
- Read the FAQ
- Post your question on this forum thread
- To learn more about the new features and improvements of OctaneRender 4, please check out our blog post.
Limitations
Refer to the on-line manual
Download Links
Current STABLE build (Octane 2019.1.1)
Release Notes
2019.1.1.26 (03-Oct-2019)
- Compiled with Octane 2019.1.1
- Added 5 new Material Layer nodes from Octane 2019.1
- Added the Vertex Displacement node from Octane 2019.1
- Added Composite, Layered and Shadow Catcher material nodes from Octane 2019.1
- Added the Round Edges node from Octane 2019.1. Any previous Octane version Rounded Edge Radius settings on material will be lost
- Added Layer pins to the Diffuse, Glossy, Specular, Metallic and Universal material nodes
- Added Up-Sampler pins to the Imager node
Re: OctaneRender 2019 for Inventor [TEST and STABLE]
Posted: Tue Apr 07, 2020 4:53 am
by scottmoyse
Are there any videos showing what this looks like inside Inventor these days? I'm still on V2, so it looks like the upgrade from V2 to V3/4 isn't free like it is from V3 to V4.
Posted: Thu Apr 09, 2020 6:22 am
by face_off
scottmoyse wrote:Are there any videos showing what this looks like inside Inventor these days? I'm still on V2, so it looks like the upgrade from V2 to V3/4 isn't free like it is from V3 to V4.
Hi Scott - suggest you try the latest DEMO version from https://home.otoy.com/render/octane-render/demo/#demo.
