NVLINK for 4 2080ti
Posted: Wed Aug 28, 2019 10:01 am
by cmittenaere
Hello community,
I'm using octane render standalone 2018.3.
I've 4x rtx2080 ti wich is connect to 4 pci e 16x
Everyting work but I want use nvlink for get 2x 22 go vram.
I saw than it's import to active sli on nvidia panel config, but I can active only one sli.
So octane can active only one nvlink ...
Can you help me ?
Thank's
Re: NVLINK for 4 2080ti
Posted: Thu Aug 29, 2019 7:09 am
by nejck
Afaik you need to plug the monitor into the second 2 cards, enable SLI on them and then disconnect the monitor but put in a dummy monitor plug (possibly once you've already shutdown your PC). Then plug in the monitor into your first 2 cards and enable SLI on them again. That way you kind of trick all of the cards to still have SLI on.
Posted: Thu Aug 29, 2019 9:30 am
by glimpse
as Nejck pointed You need to do that in specific steps, here is a bit more info on this topic.
Posted: Thu Aug 29, 2019 10:08 am
by glimpse
"To use SLI with NVIDIA Turing GPUs, all displays must be connected to the master GPU"
from driver release notes
Posted: Wed Feb 26, 2020 6:17 pm
by jimho
I also tried for quite a few times, 2x2 Sli seems not working, seems it is Nvidia not allowing this happen,
not sure otoy can make it work on the both pairs, guess it need to jump over the nvidia control panel's setting...
Posted: Wed Feb 26, 2020 6:20 pm
by jimho
glimpse wrote:as Nejck pointed You need to do that in specific steps, here is a bit more info on this topic.
Hi Glimpse, Could you give some hint on what the facebook said,
I am at a place where have no access to facebook...
Jim
Posted: Wed Feb 26, 2020 8:28 pm
by SSmolak
Posted: Wed Feb 26, 2020 10:30 pm
by jimho
SSmolak wrote:It will not work anymore : https://www.nvidia.com/en-us/geforce/fo ... udio-driv/
Thanks for the info,
Guess it will never back...
Posted: Thu Mar 19, 2020 9:48 am
by jimho
It seems even for quadro, nvidia drivers do not support multiple pairs...
https://www.pugetsystems.com/labs/artic ... s-10-1688/
