Sharpness !
Posted: Wed Aug 21, 2019 12:50 pm
by BorderLine
Hello,
I need to have the best setting possible for maximum sharpness.
Someone can help me ?
I've 6 Titan X, no problem with render time !
Re: Sharpness !
Posted: Wed Aug 21, 2019 4:37 pm
by KVNOODLES
You can play with the Filter Size option in the kernel options.
By default the value is set to 1.25, but you can reduce it to 1...
Values under 1 may cause crisp glitches.
Be carreful to the Hot Pixels Visibility is set to 100% or 1.0, values under 1.0 can be use to remove some isolated grain in your image, but you'll loose the sharpness, same thing if you use the denoiser in the Imager Camera...
Re: Sharpness !
Posted: Wed Aug 21, 2019 4:50 pm
by BorderLine
Interesting ! Thanks !
