TOPs Deadline
Posted: Fri Jun 28, 2019 2:57 pm
Hello,
I'm having some issues rendering image sequences using TOPs and Deadline:
I'm using a ropfetch in TOPs, which works fine as long as I render one frame per batch. (but that means one Deadline job per frame)
The issue comes when I check the "alll frames in one batch" option or if I increase the "frames per Batch" setting to something higher than 1 : I get an error in deadline : "Process returned non-zero exit code '1')"
I thought at first the issue might be from Houdini or Deadline, but when I do the same operation with Mantra, it renders all fine.
I've attached the working Mantra file and non working Octane file.
Any idea what that could be?
( I'v followed these instructions to set up PDG with Deadline:
http://www.sidefx.com/docs/houdini/node ... duler.html)
Houdini 17.5.229
Octane plugin 4.05
deadline 10.0.26.0
Houdini 17.5.229
Octane plugin 4.05
deadline 10.0.26.0
