Object Layer IDs Dont work with Forest Pack Objects
Posted: Sun Jun 02, 2019 9:41 pm
by nildoe
Hello..
I wanna isolate a forest pack made of grass.. If i assign an Object layer to it and use the render layer feature and select only that layer ID..it will not render at all.
Re: Object Layer IDs Dont work with Forest Pack Objects
Posted: Mon Jun 03, 2019 6:05 am
by HHbomb
HI, Multiscatter and Forest are Always rendered in ID 1....
Posted: Mon Jun 03, 2019 6:44 am
by nildoe
Thanks HHBomb...but the problem arises when you want to isolate different Forest Objects in the same scene! :(
I have a scene with forest grass and right next to it some forest bushes... i wanna color correct the grass ONLY... how would render a pass to isolate it ? Any ideas?
N
Posted: Mon Jun 03, 2019 7:27 am
by HHbomb
One dirty solution is :
- Hold scene
- Apply Diffuse material pur white color to grass (all objects which are in Forest list)
- Apply Diffuse material pur black color to all other objects
- Render "Diffuse filter" (beauty) 128 samples
- Fetch scene...
And you have a mask of the grass...
Posted: Mon Jun 03, 2019 7:40 am
by nildoe
thanks for the tip Bomb....I guess I'll have to go thru and use your trick! :)
