Task Manager show my 2nd gpu is not running?
Posted: Sat May 18, 2019 10:48 pm
by nicspoon
Task Manager show my 2nd gpu is not running, can anyone help?
I did turn off my SLI, and make sure I check "use all GPU"
Re: Task Manager show my 2nd gpu is not running?
Posted: Sun May 19, 2019 8:06 am
by aoktar
Be sure by doing render tests for selecting the one vs. two gpu on renders. You can compare render speed and times.
Posted: Sun May 19, 2019 8:50 am
by nicspoon
aoktar wrote:Be sure by doing render tests for selecting the one vs. two gpu on renders. You can compare render speed and times.
Thanks for replying Aoktar, sorry that I don't get what u mean.
My 2nd GPU showed 0%, and 1st gpu is the only one running from 15% to 90%.
Hope anyone can help give me some idea how i can slove this problem. thanks in advance!
Posted: Sun May 19, 2019 8:59 am
by aoktar
I mean be sure that's really not used by renderer. How do u know octane is not using second gpu? You can check gpu usage in render image. Check bottom line of render image for green gpu bars.
Posted: Sun May 19, 2019 10:11 am
by nicspoon
aoktar wrote:I mean be sure that's really not used by renderer. How do u know octane is not using second gpu? You can check gpu usage in render image. Check bottom line of render image for green gpu bars.
oh thanks Aoktar, I downloaded GPU-Z to check, an realize both GPUs are running.
Just curious why task manager only show 1st gpu running, but not the 2nd gpu.
Posted: Sun May 19, 2019 6:57 pm
by TonyBoy
"why task manager only show 1st gpu running, but not the 2nd gpu.[/quote]
Curious enough to check with the Windows support? I am but lack two GPUs.
