Can't enable all GPUs
Posted: Wed May 08, 2019 1:27 am
by mcaballeroadv
This is an issue that I'm dealing with on both R19 and R20, each using a different version of Octane.
When I go to Settings>Devices and I select my 3 GPUs (GTX 1080, GTX 1080 Ti, RTX 2080) it still won't use one of my GPUs. As soon as I close the settings window and I open it again, only 2/3 cards is selected. I can't seem to select all three and save the settings. I tried adding a preset under Presets>Add new preset, but as soon as I open the settings again there is one card that remains unselected. Any ideas on how to fix this issue?
Re: Can't enable all GPUs
Posted: Wed May 08, 2019 8:24 am
by glimpse
hi there,
if You have monthly subscription, it is limited to two cards. So in order to work with more cards You need different licence to start with. I guess that's Your case.
Posted: Fri May 10, 2019 12:18 am
by mcaballeroadv
glimpse wrote:hi there,
Thanks, Glimpse. Do you happen to know which is the next up license that will allow me to use 3 cards?
Posted: Fri May 10, 2019 2:04 am
by mcaballeroadv
I'm confused as to the GPU limitations. On this link it states Octane v4 supports more than 2 GPUs under the subscription plan: viewtopic.php?t=69646
But when I go to the subscription page it lists the 2 GPU limit again: https://home.otoy.com/render/octane-ren ... criptions/
Am I missing something here?
Posted: Fri May 10, 2019 12:39 pm
by glimpse
mcaballeroadv wrote:I'm confused as to the GPU limitations. On this link it states Octane v4 supports more than 2 GPUs under the subscription plan: viewtopic.php?t=69646
V4 monthly subscription did have more cards, but from 2018 You can only use up to two cards at the same time. Unless, You have full licence + Annual extension (200/Year), that now supports up to 40 GPUs.
Posted: Sat May 11, 2019 5:08 pm
by hpeskobar
Can someone post the right link on what to purchase for cinema4d plug in
For 3 GPUs and up
It’s so confusing
Posted: Sun May 12, 2019 12:38 pm
by glimpse
hpeskobar wrote:Can someone post the right link on what to purchase for cinema4d plug in
For 3 GPUs and up
It’s so confusing
all You need to get is one of these: https://home.otoy.com/render/octane-render/purchase/
or if You already have v3/v4, simply choose upgrade and take Annual extension:
