Update octane viewport parameters
Posted: Tue Apr 23, 2019 1:23 pm
by HHbomb
I use some script to configure render with octane , in fact I rarely render an image, I use octane viewport instead.
Sometimes I set max samples by script or in render setup window, the value don't change in octane viewport window.
Is there a way to refresh the viewport parameters ?
Re: Update octane viewport parameters
Posted: Tue Apr 23, 2019 4:01 pm
by paride4331
Hi HHbomb,
Render set up windows seems to work fine setting samples, Which Octane version are you using?
Posted: Thu Apr 25, 2019 12:47 pm
by HHbomb
Hi, Paride. I use 2018.1 7.05
Just try this macro script. Run it and a list appear under mouse location
When I use it, max samples are changed in Max render setup window, but not in octane viewport.
When I run it as a script in Maxscript listener, it change max sample in octane viewport too.
