Tri planar node
Posted: Wed Mar 27, 2019 4:11 am
by HazrulIdzwan
Hi there,
I'd like to suggest setting the option to use 1 map for all xyz inputs in the nodes.
The tri planar node is primarily used to seamlessly tile textures.
Current PBR workflows include Albedo, Roughness, Metallic, Normal maps, having to link 6 inputs per map works out to grand total of 24 mouse movements per material. +6 more if you include displacements.
This becomes tedious in a scene where multiple tiling materials are being utilized. The workaround currently is to clone the material's node setup and redirect the image nodes to different file paths.
Kind Regards,
Re: Tri planar node
Posted: Wed Mar 27, 2019 4:45 am
by aoktar
It's a feature we have.
Re: Tri planar node
Posted: Wed Mar 27, 2019 5:09 am
by HazrulIdzwan
Understood, it is an oversight on my part!
Many Thanks for pointing it out.
