OctaneRender 2018 for Inventor [OBSOLETE]
Posted: Thu Mar 21, 2019 2:53 am
by face_off
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Inventor - TEST and STABLE releases.
Inventor Version
The plugin requires Inventor 2018-2020, Windows 64bit.
License upgrade
Unless you have a subscription license, you will have to upgrade your version 3 licenses to version 4. This upgrade is free and can be done via these 4 steps: To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 387 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Network Rendering
For Network Rendering, you must use the Octane slave release from the Octane Standalone installer which matches the exact Octane version of the plugin you are using. This version matches OctaneRender Standalone 4.00.
Support Issues
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Nvidia driver version
- Inventor version and build number
- OctaneRender for Inventor version (ie. 1.20.1.10)
For more information
- Check the specific Octane 2.0 features in this plugin at http://render.otoy.com/manuals/Inventor/?page_id=563
- Read the on-line manual
- Read the FAQ
- Post your question on this forum thread
- To learn more about the new features and improvements of OctaneRender 4, please check out our blog post.
Limitations
Refer to the on-line manual
Download Links
Current STABLE build (Octane 2018.1.2)
Previous STABLE build (Octane 2018.1)
Release Notes
2018.1.2.25 (12-May-2019)
- Compiled with Octane 2018.1.2
- Added support for Inventor 2020 and removed support for Inventor 2017
2018.1.0.24 (21-Mar-2019)
- Implements the new Render Passes Cryptomatte functions from Octane 2018.1
- Does not implement the new Vectron, Volumetric Spotlight or Vertex Attributes from Octane 2018.1.
Re: OctaneRender 2018 for Inventor [TEST and STABLE]
Posted: Sun May 12, 2019 1:40 am
by face_off
I have updated the STABLE installers at the top of this thread with:
2018.1.2.25
Re: OctaneRender 2018 for Inventor [OBSOLETE]
Posted: Thu Oct 03, 2019 2:10 am
by face_off
This version of the plugin is now obsolete, and replaced with viewtopic.php?f=63&t=72809.
