OctaneRender 2018 for Rhino (OBSOLETE)
fabrizio_s
Rhino 6 SR14
Rhino 6 SR14
The plugin was built with SR15 - is that available to you?
fabrizio_s
No...it's strange...
I think I have probably built the plugin with the latest SR Candidate of Rhino. I will rebuild and post here for you to test.
I have updated the Rhino6 installers at the top of this thread to work with Rhino6 SR14 (and not require SR15 candidate as the previous version required).
fabrizio_s
Thank you very much Paul!
fabrizio_s
Hi Paul,
the new version has some problems.
The projects have no materials applied to the objects. All the scene is grey, hdri seems not to be applied. Live updated are not checked. Exposure has not the original value..and so on. All the scene seems to be reset
bye
Can you provide a .3dm which exhibits this problem please?
Hi Fabrizio. Thanks for sending through the scene. There is indeed definitely a problem there. If you Start Rhino, Load you scene, start rendering, then load your scene again, it appears to be OK. But I will try to get a fix released ASAP.
I have updated the STABLE build at the top of this thread with:
2018.1.3.109
- Compiled with Octane 2018.1.3
- Fixed issue where loading or importing scenes after the first scene had been loaded was incorrectly setting the rendertarget settings
Return to “Rhinoceros 3D”
