Network render without eGPU
Posted: Fri Mar 01, 2019 10:15 pm
I'm looking to set up a workflow where I work off my Macbook Pro and then network render with Octane using a windows renderslave. My original plan had been to get an eGPU for the MacBook Pro and use that in conjunction with the 4 GPUS in my renderslave using network render as seen in this tutorial https://www.youtube.com/watch?v=Vvf_-toAOU8 to have a total of 5 GPUS rendering in IPR and etc
However, I was wondering if the eGPU is actually necessary to do this? For instance would it be doable to have a setup where you have a MacBook Pro with the correct CUDA drivers installed etc, no actual eGPU, and then network render using a Renderslave that also has Octane?
Thanks for your time and help!
