[SOLUTION] Remove duplicate materials from Rhino MTL files
Posted: Thu Jun 23, 2011 11:11 am
by tom_holly
I've uploaded a script to remove and sort the duplicate materials in MTL files when exporting OBJ files from Rhino 3D.
It works for Rhino 4. It may or may not work for other versions.
This is not fully tested, so use at your own risk. You may post any bugs to me on this thread.
http://rhino-3d-obj-mtl-fix.zzl.org/
Cheers, Tom
Re: [SOLUTION] Remove duplicate materials from Rhino MTL files
Posted: Thu Jun 23, 2011 12:46 pm
by tom_holly
Just updated the content on the website link to include instructions on exporting from Rhino.
Posted: Sun Jul 24, 2011 11:29 am
by rock1ng
Hello Tom, I was trying to solve the problem with your solution, but the program shows me this message:
There was an error parsing the command-line arguments:
Couldn't find match for argument Argument: octane.obj
USAGE:
dummy program name [-m <string>] [-r <filename>] [-l <filename>] [-n
<filename>] [--imager-exposure <float>]
[--daylight-sundir-z <float>] [--daylight-sundir-y
<float>] [--daylight-sundir-x <float>]
[--cam-lensshift-right <float>] [--cam-lensshift-up
<float>] [--cam-aperture <float>] [--cam-focaldepth
<float>] [--cam-fov <float>] [--cam-motion-up-z
<float>] [--cam-motion-up-y <float>]
[--cam-motion-up-x <float>] [--cam-motion-target-z
<float>] [--cam-motion-target-y <float>]
[--cam-motion-target-x <float>] [--cam-motion-pos-z
<float>] [--cam-motion-pos-y <float>]
[--cam-motion-pos-x <float>] [--cam-up-z <float>]
[--cam-up-y <float>] [--cam-up-x <float>]
[--cam-target-z <float>] [--cam-target-y <float>]
[--cam-target-x <float>] [--cam-pos-z <float>]
[--cam-pos-y <float>] [--cam-pos-x <float>] [-q] [-g
<int>] ... [-s <int>] [-o <filename>]
[--film-height <int>] [--film-width <int>] [-e] [--]
[--version] [-h] <filename>
Where:
-m <string>, --mesh-node <string>
Name of meshnode to render
-r <filename>, --relink-meshnode <filename>
Name of OBJ mesh file to relink rendered meshnoded with
-l <filename>, --link-meshnode <filename>
Name of OBJ mesh file to link after startup
-n <filename>, --new <filename>
Create a new OCS project file from given command line arguments
Imager Exposure Amount
Daylight Sun Direction Vector Z Component
--daylight-sundir-y <float>
Daylight Sun Direction Vector Y Component
Daylight Sun Direction Vector X Component
Lens Shift Right
--cam-lensshift-up <float>
Lens Shift Up
Camera Aperture Radius
--cam-focaldepth <float>
Camera Focal Depth
--cam-fov <float>
Camera FOV (degrees)
--cam-motion-up-z <float>
Camera Up Motion 2nd Vector Z Component
Camera Up Motion 2nd Vector Y Component
Camera Up Motion 2nd Vector X Component
--cam-motion-target-z <float>
Camera Target Motion 2nd Position Z Component
Camera Target Motion 2nd Position Y Component
Camera Target Motion 2nd Position X Component
--cam-motion-pos-z <float>
Camera Motion 2nd Position Z Component
Camera Motion 2nd Position Y Component
Camera Motion 2nd Position X Component
--cam-up-z <float>
Camera Up Vector Z Component
--cam-up-y <float>
Camera Up Vector Y Component
--cam-up-x <float>
Camera Up Vector X Component
Camera Target Position Z Component
Camera Target Position Y Component
Camera Target Position X Component
--cam-pos-z <float>
Camera Position Z Component
--cam-pos-y <float>
Camera Position Y Component
--cam-pos-x <float>
Camera Position X Component
-q, --quiet
Start Application without splash and minimized window
-g <int>, --gpu <int> (accepted multiple times)
add GPU device to use for rendering (0 = first)
-s <int>, --samples <int>
Maximum number of samples per pixel (maxsamples)
-o <filename>, --output-png <filename>
Output PNG imagefile when maxsamples is reached
--film-height <int>
Film height
--film-width <int>
Film width
-e, --exit
Close the application when rendering is done
--, --ignore_rest
Ignores the rest of the labeled arguments following this flag.
--version
Displays version information and exits.
-h, --help
Displays usage information and exits.
<filename>
.OCS Project scene file
Octane Render
Can you tell me what is it ? thank you a lot.
Posted: Mon Jul 25, 2011 8:32 am
by tom_holly
Hello,
You appear to be trying to process the OCS file, you should be processing the contents of the MTL file.
When you export an OBJ file from Rhino, it creates an MTL file which contains the list of materials. It is the contents of this file you paste and process.
If you have any problems, please let me know.
Cheers, Tom
Posted: Mon Jul 25, 2011 10:25 am
by pixelrush
Pardon me tacking on here but the link to the mod script doesnt seem to be working.
Can you re upload it somewhere please.
I recently bought Rhino and would like to try exporting to Octane.
thanks
Posted: Mon Jul 25, 2011 11:56 am
by tom_holly
I just tried the link and it works fine for me.
Perhaps the site hosting it was down for a while?
Cheers, Tom
Posted: Mon Jul 25, 2011 9:02 pm
by rock1ng
tom_holly wrote:Hello,
Cheers, Tom
Thanks, i will try it.
Posted: Mon Jul 25, 2011 9:13 pm
by pixelrush
Sorry to say every time I try the link lately and today I get 'could not connect to server' error.
Tried both IE and Opera. The google cache version is missing the code...
Any reason why you cant put it here on the forum? We would appreciate it.
Posted: Wed Jul 27, 2011 9:32 am
by pixelrush
ok still not working
I give up. I'll go through Blender...
