OctaneRender for Maya 2018.1rc1-14.10 [OBSOLETE]
Posted: Thu Jan 17, 2019 11:15 pm
by JimStar
Forum rules:
!!! THIS IS THE BETA VERSION OF OctaneRender PLUGIN, IT IS RELEASED FOR INITIAL BUG HUNTING ONLY !!!
!!! PLEASE DON'T USE IT FOR PRODUCTION & DON'T SAVE THE SCENES FROM THIS BETA VERSION FOR FUTURE USE AS THERE ARE HIGH CHANCES TO LOSING THEM !!!
!!! SCENES SAVED IN THIS BETA VERSION ARE NOT GUARANTEED TO WORK IN SUBSEQUENT VERSIONS !!!
!!! THE RENDER ENGINE IS YET TO BE STABLE, SOME CRASHES & BUGS ARE EXPECTED FOR THIS TEST VERSION OF THE PLUGIN !!!
Otoy® is proud to announce the availability of a new test version of OctaneRender™ for Maya® Version 2018.1
Maya® Version Requirements
This release will work with Maya® Versions 2016, 2016.5, 2017 and 2018 64-bit on Windows, Linux and OSX operating systems.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 387 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Changelog and the installers for Octane Standalone 2018.1 are here:
OctaneRender Standalone 2018.1 RC1
Changes since version 14.9:
  • Implemented one more workaround for several Maya's region API bugs. Should now retain the region-marquee between rendering sessions.
Windows DOWNLOAD
OctaneRender for Maya 2018.1rc1-14.10 BETA
Linux DOWNLOAD
MacOS DOWNLOAD
Subscription Studio Downloads
OctaneRender for Maya Studio 2018.1rc1-14.10 BETA [Windows]
OctaneRender for Maya Studio 2018.1rc1-14.10 BETA [Linux]
OctaneRender for Maya Studio 2018.1rc1-14.10 BETA [MacOS]
Re: OctaneRender for Maya 2018.1rc1-14.10 [BETA]
Posted: Sun Jan 20, 2019 7:50 pm
by Dennyuel
Hi Jim!
Since version .9 the denoiser is only working if you update the pass in the passes after each IPR render.
Test StepByStep Flow
- Start maya open or create any octane scene
- Set up passes to preview denoiser output.
- Start IPR
- See there is no denoiser in the view.
- Update again the pass by changing out denoiser output and putting it back again.
- Denoise is visible
- Hit IPR again
- Denoise output is missing from render view again....
Can you look into the matter as its hard to work like this.
Posted: Mon Jan 21, 2019 12:04 am
by JimStar
Dennyuel
Works OK for me, no difference with the 14.8: the denoised image kicks in after some time of rendering (before that the beauty image is shown in the result) or after the rendering reaches the max-samples - depending on your settings. You don't need to be changing the preview-pass back and forth for that - the denoised image appears when it's ready.
If you want the denoised result earlier than the rendering got finished, just make sure you've unset the "Denoise on completion" checkbox in the imager settings. But this mode is more resource-hungry.
Posted: Tue Jan 22, 2019 11:22 am
by 3dstarmodels
Hi, JimStar.
I want rendering sequence in maya. but when I am start rendering in batch render - batch render crashed(( I am test on stable version same errors. Maybe have other method for render sequence in maya with octane?
Posted: Tue Jan 22, 2019 7:56 pm
by JimStar
Posted: Wed Jan 23, 2019 7:23 am
by intelligentlight
Hello JimStar!
Thanks a lot for all of your great work. Any idea when this or the 4.x stable plugin will support Maya 2019?
Cheers!
Posted: Wed Jan 23, 2019 4:48 pm
by 3dstarmodels
Hi, JimStar.
I know how rendering in batch render. But maya crashed. I am attached screenshot.
Posted: Wed Jan 23, 2019 5:59 pm
by JimStar
3dstarmodels
Please write the proper reproduce-sequence description and PM me the scene where this happens.
