maya plugin vs stand alone issues
Posted: Sun Dec 30, 2018 4:43 am
by sarichev
im working with several space scenes that are a bit large, i just got the plugin for maya but i cant get it to work properly. every scene im trying to render even the simple lookdev ones are:
1. have huge banding issues - low light kind of banding
- its everywhere : IPR / viewport / render
- r epsilon doesnt help
- i set my output as 16bit png but other 16bit give same result
2. the whole maya interface gets extremely laggy
- im talking like i can barely move a node in the shaderview
- the render is definately slower than with teh same exact scene ( exported from maya) in the stand alone.
if i save out the same scenes as orbx and render in standalone there is no banding and no lag.
i REALLY dont want to change my workflow and go render through stand alone that would be ridicules.
please help,
Sergei
Re: maya plugin vs stand alone issues
Posted: Sun Dec 30, 2018 4:54 am
by sarichev
apparently dithering was turned off as a preset?
so banding looks much better but the lag is still not solved. any ideas would be great
thanks
Posted: Sun Dec 30, 2018 5:35 pm
by Refracty
You should combine as many objects as possible. That will remove the lag.
Posted: Sat Jan 05, 2019 12:24 pm
by sachakogel123
Do you have any animated Octane shaders, I am having an issue where if I animate an octane shader like say the emission attribute to simulate a light flicker or flash then my scene becomes EXTREMELY laggy to the point where I just convert back to Arnold and carry on as the scene aslo becomes very unstable and crashes allot.
Posted: Tue Jan 22, 2019 4:21 am
by sarichev
i dont have anything animated in the scene, im was doing some space scenes with earth at about a 1/100 scale and using 8k textures and its extremely slow and laggy
Posted: Wed Jan 23, 2019 8:04 pm
by calus
high res octane textures in viewport slow down Maya a lot,
to prevent that, in render setting set texture resolution to 1 and texture and swatch quality to 0:
