OctaneRender™ 2018.1 for Houdini™ beta build 2018.1.0.0 XB2
Posted: Tue Dec 25, 2018 7:31 pm
This is the first beta release of the OctaneRender™ 2018.1 for Houdini™ plugin compiled with the Octane 2018.1 XB2 core. This 2018.1.0.0 release is available for the Houdini 16.0/16.5/17.0 latest production builds on Windows x64, Linux gcc6.3.1 and OSX 10.12. This plugin is also compatible with Houdini Indie (While working inside the Indie version, the plugin will have a 4k limited resolution while rendering sequences and the scene export and cloud rendering features disabled)
As with all experimental releases, please do not use this for production purposes. 2018.1 XB2 will expire in 60 days
New features
To learn more about the new features and improvements of OctaneRender 2018.1, please check out the 2018.1 release post, but this a quick list of the main new features that have been added:
Release 2018.1.0.0 regular license
https://render.otoy.com/customerdownloa ... _Win64.zip
https://render.otoy.com/customerdownloa ... _Linux.zip
https://render.otoy.com/customerdownloa ... ni_OSX.zip
Release 2018.1.0.0 subscription license
https://render.otoy.com/customerdownloa ... n64_vr.zip
https://render.otoy.com/customerdownloa ... nux_vr.zip
https://render.otoy.com/customerdownloa ... OSX_vr.zip
Standalone 2018.1 XB2 version for the network rendering nodes
https://render.otoy.com/customerdownloa ... B2_win.exe
Happy rendering,
Your OTOY Team
New features
- NV Link support on RTX 2080 and RTX 2080 Ti
- Cryptomatte. Currently, in the Houdini plugin the Instance ID is used also as Object ID due to its internal scene graph architecture.
- Vertex Attributes in the mesh objects. New options in the Octane OBJ spare parameters to configure the attributes to be extracted.
- New "Color Vertex Attribute" and "Float Vertex Attribute" VOP nodes to retrieve the vertex attributes in the shaders.
- Deep render passes.
- Way less Volume Render Noise. New option in the kernels to disable this feature if the matching of the Octane v4 volumes is needed.
- Direct Levelset surface rendering. New option in the Octane OBJ spare parameters to configure the volumes and OpenVDB rendering to work with SDFs.
- Scatter depth limiting (i.e. fast fog rendering)
- Overall 5% faster than V4 stable (about 315 OB vs 298 OB in our tests)
- GPU compressed textures are now cached (big time saver for many - based on your V4 feedback )
Happy rendering,
Your OTOY Team
