OctaneSetup Layout Suggestion
Posted: Thu Dec 20, 2018 1:53 pm
by marcus1070
Hi Paul, and everyone!
I did some layout changes in setup window, and i think its a good change for the plugin usability.
Moving the Octane Node Properties to the right of Octane Schematic Left Panel, it gives more flexibility to work free on node properties without scrolling.
o/ cheers
Re: OctaneSetup Layout Suggestion
Posted: Fri Dec 21, 2018 8:24 am
by face_off
Thanks for the suggestion. I have found the layout preference can be different for every user (and every different screen resolution). With some tweaking you can save your layout to override the default plugin layout as per the approach outlined at https://docs.otoy.com/ModoH/ModoPluginM ... KitFor.htm (although that is for userValues, but it should also work for the layout).
