Camera screen window size doesn't match Houdini viewport.
Posted: Sun Dec 16, 2018 5:25 pm
by Hampayon
Hi!
H17, Octane 4 latest plugin.
Camera screen window size parameter doesn't match between viewport and octane.
A bug?
Br,
Hamp
Re: Camera screen window size doesn't match Houdini viewport.
Posted: Mon Dec 17, 2018 9:51 pm
by juanjgon
Are you talking about the IPR window render solution? There is a set of options in the pugin options panel, IPR tab, to configure the default IPR windows size.
https://docs.otoy.com/HoudiniH/HoudiniP ... ptions.htm
Hope it helps,
Posted: Tue Dec 18, 2018 9:23 am
by Hampayon
Hi! No, sorry for being unclear.
I mean the settings on the camera to do post zoom/translate etc. - it's called screen window size for some reason.
Br,
HHH
Posted: Tue Dec 25, 2018 11:26 am
by Hampayon
Or is there any other octane plug-in specific place to look for when doing crop renders / tilt shift effects?
Br,
Hamp
Posted: Tue Dec 25, 2018 7:12 pm
by juanjgon
Yes, true, there is a problem with the Houdini camera Screen Window Size parameter. The Screen Window X/Y works fine, but not the size. I'll try to fix this issue for the next build, if possible (I mean, if there are no limitations on the Octane side to support this feature).
Posted: Wed Dec 26, 2018 2:11 pm
by Hampayon
Ah I see!
Fantastic, I for one use this in any renderer, especially when matching backplates that are pre-cropped.
Br,
Hamp
