Loading exr image sequences
Posted: Sun Dec 09, 2018 1:40 am
by grimm
I wanted to use an animated exr image sequence for a water displacement texture. I was able to point to it using the texture node, but when I tried to render, OctaneServer complained that it couldn't load the texture. This works in standalone and renders ok. Thanks,
Jason
Re: Loading exr image sequences
Posted: Tue Jan 15, 2019 1:00 pm
by DrawFun
Hi, grimm,
Thanks for your report. The Octane Image Tex should support image sequence in the latest build(17.1). Perhaps I missed something. Could you please show me a simple demo(blender or orbx) about that? Thanks.
Cheers,
DrawFun
Posted: Thu Jan 17, 2019 6:07 am
by grimm
Hi Drawfun,
Thanks, It's just a simple animation of a bowl with a plane in it for water. I have an animated water image sequence in EXR format that I'm using to displace the surface with. I just tested it again with 17.1 and I get the same error, although I can export an ORBX file and it works fine in stand alone. It appears that I can not use EXR images for displacement in the plugin. Here is the error message:
Octane Engine v. 17.1
Octane: Starting Octane engine...
Work Scheduler initializing 12 worker threads
Octane: ...started
Octane: Activating license...
Octane: ...activated
Octane: LiveDB cache refresh started...
Octane: unknown ERROR: 79
Octane: LiveDB cache refresh complete
Octane: ERROR: Error transferring the texture file to the server.
Posted: Tue Jan 22, 2019 8:06 am
by DrawFun
Hi grimm,
It works under my tests. Here is a demo scene. Could you please check it on your end? Thanks.
The exr files are located in the same directory. The naming pattern is 1.exr, 2.exr, 3.exr ...
Cheers,
DrawFun
Posted: Tue Jan 22, 2019 5:28 pm
by grimm
Hi Drawfun,
Thanks for looking in to this, but I'm still getting the error.
Octane: ...started
Octane: unknown ERROR: 75
All I did was to load your .blend file, set the view port to render, and then I scrubbed the timeline to move through the frames.
Jason
