issue visualizing F9 render Octane 4.0
Posted: Sat Dec 08, 2018 4:21 pm
by spigolo
Im making some test with new Octane version ,
but when I render pressig F9 (with denoiser active) it foesnt show in the FB the render
What might be?
Re: issue visualizing F9 render Octane 4.0
Posted: Sat Dec 08, 2018 4:45 pm
by spigolo
I mean,
I render I see the overall process but at the end it saves a black picture ...
I think is something related to the denosier but I don't know what...
Posted: Sat Dec 08, 2018 4:53 pm
by 3dworks
i have experienced (and juanjo confirmed) that the denoiser has issues with images larger than 4K, so maybe if you are rendering large size images, that could be a reason?
Posted: Sat Dec 08, 2018 5:16 pm
by spigolo
hmm no it was just a 1600*1000 px image a quick test
Posted: Mon Dec 10, 2018 5:19 pm
by juanjgon
Are you working with the latest 4.00.0.21 plugin build? How are you saving the images ... probably you should try to save them from the passes node to see if it helps.
Posted: Mon Dec 10, 2018 7:19 pm
by spigolo
Hello,
all render i do with denoiser and PCM comes black evensaving image with render passes
Posted: Mon Dec 10, 2018 9:24 pm
by juanjgon
The problem is that PCM kernel is not compatible with the denoiser yet. You must use the direct lighting or path tracing kernels with it.
