Ohh now THAT explains it, then. I was adding suffixes to the grouping names, like "Furniture_GRP". Can't the code search grouping objects by ID? I know Poser Python has a unique ID for each kind of object it can manipulate. That would leave me free to name them using my own standards.Zay wrote:It seems the plugin is looking for the name "Grouping" and hide it if it finds it. If you rename it, the grouping box will show in the plugin.
So rename it to "Grouping Room" will work, but "Room" will not work it seems.
OctaneRender 4 for Poser [OBSOLETE]
I have updated the Windows installer at the top of this thread with:
4.05.0.97
- Compiled with Octane 4.05.0
- Resolves issues when running on Poser11.2
4.05.0.97
With the latest update you've implemented a version checker, which is nice, but it seems to not be properly working currently. Just a minor bug.
It pops up every day when starting.
It successfully tells me that I use version 4.05.0.97 but the latest version is "Unknown", therefor my current version is always "out of date"
Hi - this has been fixed, and I thought I updated the links at the top of this thread. Could you pls try re-downloading and installing 4.05.0.97 and let me know if that resolves your error. If not, can you please send me the octaneplugin.log file after the warning pops up.It successfully tells me that I use version 4.05.0.97 but the latest version is "Unknown", therefor my current version is always "out of date"
I'm sorry but there still seems to be something incorrect.
I installed the latest version again yesterday, and just started it up today. After initialising the render window for the second time today over the course of about 15 minutes, the notice popped up on the second opening.
I've located the octaneplugin.log but the file itself is empty (last change date is set to a timestamp when the render window was opened first time today, not the second when the notice came up).
I will check again tomorrow when I first start the render window.
I'm getting this issue. I've re-downloaded and re-installed. And, I still get this issue. It seems to only show up once per day. I zipped and attached the log file.face_off wrote:Hi - this has been fixed, and I thought I updated the links at the top of this thread. Could you pls try re-downloading and installing 4.05.0.97 and let me know if that resolves your error. If not, can you please send me the octaneplugin.log file after the warning pops up.It successfully tells me that I use version 4.05.0.97 but the latest version is "Unknown", therefor my current version is always "out of date"
- Attachments
- octaneplugin.zip
- (17.17 KiB) Downloaded 1095 times
Hi - could you try this version please?
https://render.otoy.com/customerdownloa ... _Win64.exe
So I guess bye, bye Octane Renderer Version 4 for Poser version 12?
An errror occurred importing addon OctaneRender for Poser :
ERROR: bad magic number in 'OctaneRender for Poser': b'\x03\xf3\r\n'
WEB: http://rgus.deviantart.com/
GPU: NVIDIA GeForce RTX 3090 Ti
RAM: 64GB
CPU: 12th Gen Intel(R) Core(TM) i9-12900K 3.20 GHz
OPERATING SYSTEM: Windows 11 Pro
OCTANE PLUGIN VERSION: 2025.6.0.4.5 Prime
DAZ STUDIO VERSION: 4.24 Pro Edition (64 bit)
RAM: 64GB
