Aplication error, not enought memory...
Posted: Sat Nov 03, 2018 10:24 pm
by imago10
I have problem with Octane and Cinema 4D. I've got info that Cinema 4D R17 64bit don't have memory or Application error, But max only half RAM memory is used and about 800MB of 11GB VRAM. I try different version of Octane but still same (now I have 4.0 RC5). I turn off CPU/CPU OC but that doesn't help.
I also try fresh install. Still same errores...
Also I extend paging file on W7 but that doesn't help
I also attached my last bugreport log. Could you please help me? And give me any tips how to solve it?
Lukas
Re: Aplication error, not enought memory...
Posted: Sat Nov 03, 2018 11:17 pm
by aoktar
Well, first I need to know what do you have in your scene and is it happening every scene or in a spesific one.
Posted: Sat Nov 03, 2018 11:26 pm
by imago10
Sadly on every scene but sometimes after 10 frames sometimes after 50 rendered frames... Always when I render animation
Posted: Sun Nov 04, 2018 12:29 am
by aoktar
Could you record a video while memory usage visible in task manager and render stats visible in picture viewer. Also I need to see console output in this video.
Posted: Sun Nov 04, 2018 10:16 pm
by GIOLETS
Try also to give a look if your Windows Paging file exist or is too small. In case you can manually set the size of the file.
Seems to be a Cinema4d (or Windows7) memory problem, not related to Octane.
Posted: Mon Nov 05, 2018 5:35 pm
by aoktar
Please answer to narrow down the issue, are you using render passes when this problem appear?
