Linux Version
Posted: Fri Jun 10, 2011 8:40 pm
by face
I'm happy to say, that a version for Linux is on the way...
The current status is, that i can export polygon meshes in the project folder and the most PPG checks are working.
I have rewritten the structure of the program, so that's easier for me to change/read old things.
Some parts of the program are also rewritten, it makes the response time a little bit faster.
The PPG have little changes, so that you can now en/disable the export of the lens values (Aperture/Focal depth).
Some slider are changed from linear to logarithmic. So it's easier to change the values on the smaller number, like the Octane ones.
You have also the option to make a debug output in the script editor window.
At the moment i update the error checking system, so that you now become one warning for all errors and the hint to check the script editor window to read detailed information.
And last but not least, the name of the plugin is changed from octane_exporter to Soft2Octane.
The porting to Linux is running under my first priority. I will make all working. After that, i will porting it to Windows.
face
Re: Linux Version
Posted: Mon Jul 04, 2011 10:29 am
by face
The Linux development is stopped till the issue that i can“t exit Octane without a kill command is solved...
face
