turn off object shadows
Posted: Mon Sep 24, 2018 11:08 pm
by protovu
Hello,
New to Blender Octane.......I know this must be obvious, but I cannot find the toggle to Turn Off Object Shadows. In my Carrara Octane Plugin, this function is nested in an Octane Object Modifier.
No such Modifier in Blender, so I looked under the Object panel. While there is an Octane properties tab , it is blank for the object selected ( actually, nothing shows for any object selected).
The Octane Imager Presets ( in the "N" panel of 3D view) also offers no shadow object options.
Thank you for your help,
Rick
Re: turn off object shadows
Posted: Tue Sep 25, 2018 3:05 pm
by Whispermode
Is that (maybe) because you don't have the mesh selected? Seems odd that there's nothing there as the panel is extensive...
I don't know how to paste images, but you can see the option here in the manual:
https://docs.otoy.com/BlenderH/BlenderP ... erties.htm
'Shadow visibility' in the Visibility section.
Posted: Tue Sep 25, 2018 4:07 pm
by J.C
Strange issue. The "Octane properties" rollout in Object data tab should have many options including the option to turn off the shadow casting.
Posted: Tue Sep 25, 2018 4:34 pm
by protovu
Ahhhh..... Seems there is a decoy Octane Properties panel, and this is the one I was looking at.
With an object selected, if I look in the panel designated by the little cube, I see the blank Octane panel.
With the same object selected, if I look in the panel designated by the Triangle ( per the manual, as Whispermode kindly pointed out) I do indeed
find the desired options.
I suggest we use the blank panel to embed direct links for ordering pizza at 3 in the morning.
Thank you very much for the responses.
Rick
Posted: Tue Sep 25, 2018 7:39 pm
by Whispermode
That might well be the most important feature request ever submitted.
