Page 1 of 4
PMC dispersion bolts test
Posted: Tue Jun 07, 2011 1:04 am
by radiance
Hi all,
Here's a little test render with the new pmc kernel in 2.47+,
using dispersion on the glass bolts. (scene is by dave62, it's in our new testsuite)
It's raw output from octane, no post-proc.
The cauchy B parameter for dispersion is too high though, 0.1, it's not something any realistic materials would have, I just wanted to see as much dispersion as possible.
Radiance
Re: PMC dispersion bolts test
Posted: Tue Jun 07, 2011 1:32 am
by DayVids
Good lookin, how much is the render time affected (if at all) by this?
Posted: Tue Jun 07, 2011 2:40 am
by funk
That looks great man.
What sort of render times should we expect once you've optimised it? Will it be faster than path tracing?
Posted: Tue Jun 07, 2011 4:34 am
by hadouken
that looks really clean.
Posted: Tue Jun 07, 2011 7:44 am
by radiance
I left it running overnight, and in the morning it was finished at 16000/16000.
I don't know when it was done though, and forgot to check... (should have taken a screenshot too... :( )
It looked pretty clean after on hour though, i'm sure 2 hours would have been more than enough, and I used one GTX460 GPU.
We're still working on optimizing the PMC kernel, at this time it's difficult to predict, but I'm hoping we can get 2x speedup after the optimizations are finished,
in a few weeks with the big beta 2.5 release.
Bidirectional pathtracing (and PMC) should make renders like this one converge MUCH faster,
and bidirectional pathtracing + PMC is something we will be starting work on next, after 2.5 is out.
PMC + bidirectional will be ideal, it will be as efficient as the popular standard in CPU based unbiased engines (MLT+bidir),
and this combines with the power of GPUs should really take things to a new level.
Radiance
Posted: Tue Jun 07, 2011 8:39 am
by Jaberwocky
radiance wrote:I left it running overnight, and in the morning it was finished at 16000/16000.
Radiance
That sounds great.......More speed.......I love speed........
Careful radiance...don't feed the zombies. :lol: ;)
Posted: Tue Jun 07, 2011 10:21 am
by radiant
radiance wrote: Bidirectional pathtracing (and PMC) should make renders like this one converge MUCH faster,
Radiance
So is bidirectional path tracing like an add on or a modified version of path tracing?
What is the difference between the two?
Posted: Tue Jun 07, 2011 11:38 am
by tchoa
That is very promising!
Cheers :)
F
Posted: Tue Jun 07, 2011 12:21 pm
by radiance
Radiance
It's a more complex algorithm, it's also unbiased, produces the same result (if implemented properly),
but is more efficient for caustics and hidden lightsources, as it traces rays from lights and from the camera,
and interconnects them.
It's quite complex to implement, and requires a complete foundation, which we now have.
It can also be combined with PMC to make it even better.
Radiance
Posted: Tue Jun 07, 2011 12:39 pm
by tungee
That sounds so good!
