Page 1 of 6
Version 4.0-RC1.0 (obsolete experimental build) 15.08.2018
Posted: Wed Aug 15, 2018 8:04 pm
by aoktar
Hi All,
This is next test/preview release of plugin which is based on V4-RC1 SDK. We recommend that you mention that it is experimental, they should not use it for production work, and that we cannot guarantee backward compatibility.
Please note that this build will expire in 60 days, this is now shown on the bottom right of the standalone release.
Whilst we have reached the feature lock milestone, we consider this a non-stable release, as we expect to stabilise in preparation for the first stable. Until then, please do not use this for production purposes.
Please see this thread for V4 features: viewtopic.php?f=33&t=66013
This is matching Standalone V4-RC1: Standalone 4 RC 1
Important notes:
Since XB2 Preview, we have dropped support for Fermi cards.
Network render is still disabled.
Denoiser is under Camera Imager from Settings or Camera Tags. Just denoised beauty pass is available in plugin, others will be added.
Changes of V4-RC1.0
- Fix: Error on denoising devices
- New 1/IOR map in universal material
- ImageTexture compression added and channel format fixed
- Fix: Delete material problem while NE open
- AI volume denoiser
- Fix: Picture viewer rendering problems with denoiser and passes
- New pins added in Universal material.
- Additionally some minor fixes in plugin...
Changes of V4-XB3
- Help support for the Nodes in Node Editor
- Geometry Engine default changed to "All Movable"
- Visualisation for VDB voxels
Changes of V4-XB2.1 test2
- Fixed random material preview crashes, mostly on LiveDb
- Fix: error on OSX and reading of ScatterObject/csv files
- Added: New universal material to Octane Material and Blend material
- New options in Instance Color and XP emitter
Addons for plugin side
- Viewport rendering: Activate from Live Viewer/Octane dialog options menu. Keep open the one of these windows during the render session.
- Node Editor: Experimental float sliders on nodes. Need to activate from "settings->nodes->embedded gui".
- Node Editor: Show/hide options for node pins.
- New help system, updated manual(it's still wip). Access by help icons from nodes/etc..
- Several minor fixes.
WINDOWS REGULAR BUILD
https://render.otoy.com/customerdownloa ... .1-win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD
OSX REGULAR BUILD
https://render.otoy.com/customerdownloa ... Macosx.zip
OSX SUBSCRIPTION(Studio) BUILD
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053). Otherwise the plugin will not work and not appear in menus.
-Internet connection for activation, be sure that C4D and Octane will not be blocked by firewall and any antivirus software.
-Updated Nvidia drivers(most recents like 39x.x) with Cuda 9.1 - change driver versions if you have much trouble with current driver
HELP MANUAL
Use embedded help buttons from Octane nodes and windows
V3 SAMPLE SCENES SET(make a request if you need any spesific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
First remove all octane related stuff from plugins and main folder of Cinema4D.
Also download manual.zip and extract to c4dOctane directory if it's not available in place.
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Node sliders
https://vimeo.com/268974364
Viewport rendering mode
https://vimeo.com/265747658
https://vimeo.com/265294205
Re: Version 4.0-RC1.1 (Latest experimental build) 15.08.2018
Posted: Wed Aug 15, 2018 10:42 pm
by msstrang
Exited to test this build out!
Any idea on when network rendering will be enabled? I've got a couple machines that would love to be a part of the octane 4 network.
Will post any bugs/errors I come across.
Thanks again.
Posted: Thu Aug 16, 2018 2:24 am
by msstrang
Getting a render error (Log posted below)
Posted: Thu Aug 16, 2018 3:17 am
by SRCOBB
My C4D is crashing on open with this version.
Posted: Thu Aug 16, 2018 5:39 am
by stefano-dear
Thanks aoktar for this test release!
My C4D crash after some seconds of render...
_BugReport.zip
(23.05 KiB) Downloaded 381 times
Posted: Thu Aug 16, 2018 6:13 am
by jopfe
Great release, thanks for the quick turnaround Ahmet!
Had no problem with R18.057 so far.
So hyped about saving denoiser multipass is working now - let the animations roll! ;)
Posted: Thu Aug 16, 2018 6:19 am
by Studio21
@ahmet thx for the quick release! Fake shadows is missing in the universal material?
Thx,
Guy
Posted: Thu Aug 16, 2018 8:43 am
by VVG
no crash. (AMD CPU/MB)
works fine
thanks for fast integration
I am surprised that the integration quickly rendered the scene
Posted: Thu Aug 16, 2018 9:50 am
by aoktar
msstrang wrote:Exited to test this build out!
Thanks again.
Quote from standalone notes
Posted: Thu Aug 16, 2018 9:52 am
by aoktar
VVG wrote:no crash. (AMD CPU/MB)
works fine
It should be at same speed for same scenes. Please check device priorities.
