Iray to octane
Posted: Thu Jul 05, 2018 7:02 am
by gsfcreator
Hi there, people.
I'm trying to import some pretty simple props from DAZ to poser. the DSON did fine, everything is working, but look:
Iray:
octane-poser:
I tried to set up the material to silver from live DB. still not even close. is there any way to transfer Iray nodes properly to poser/octane?
thanks <3
Re: Iray to octane
Posted: Thu Jul 05, 2018 11:25 am
by face_off
The plugin converts Poser materials to Octane material, not Iray materials to Poser materials. If there are only Iray materials, you will need to convert them manually.
Re: Iray to octane
Posted: Thu Jul 05, 2018 12:19 pm
by gsfcreator
face_off wrote:The plugin converts Poser materials to Octane material, not Iray materials to Poser materials. If there are only Iray materials, you will need to convert them manually.
I never said octane should do it for me, Paul. that's exactly what I was asking...(how to convert them manually, so it will work nice with octane-->poser).
Re: Iray to octane
Posted: Fri Jul 06, 2018 12:52 am
by face_off
I would start by loading the closest material you can find from the LiveDb and adjust the material as required from there.
Re: Iray to octane
Posted: Mon Jul 09, 2018 3:16 am
by samhal
Depending on the angle light hits some LiveDB metals, it may not look like you want. Changing direction of light can help, or the rotation of HDRI maps. You can also try other metals, Nickel, Titanium, and Chromed Steel until you get that silver look. Also copy the bump map/displacement map image from the original material and paste it into the LiveDB material to get the ornate look back.
Hope this helps.
Re: Iray to octane
Posted: Tue Jul 10, 2018 10:23 am
by gsfcreator
samhal wrote:Depending on the angle light hits some LiveDB metals, it may not look like you want. Changing direction of light can help, or the rotation of HDRI maps. You can also try other metals, Nickel, Titanium, and Chromed Steel until you get that silver look. Also copy the bump map/displacement map image from the original material and paste it into the LiveDB material to get the ornate look back.
Hope this helps.
thanks, Samhal! I got some help and getting somewhere with this. still not like the Iray render, but getting better! :)
