network rendering problem / 3dsmax
Posted: Wed Jun 06, 2018 8:35 am
by asile
Hi there
I got problem with networking render.
i can see the network slave in the stand alone. But i see nothing in the 3dsmax octane network. And i really dont want use the standalone for rendering...........
Before, with odlder version, that worked.
I use the pluggin v3.08_5.07
and standalone 3.06.4 (3.06.3 is recommanded but the link of release go to the 3.06.4).
Any idea to resolve the problem?
Have a good day all !
(sory for my english..)
__________________Ivan
http://asile-paris.com/
Re: network rendering problem / 3dsmax
Posted: Wed Jun 06, 2018 8:41 am
by paride4331
Hi Asile,
Master and slaves must have the same SDK version;
so you should use (e.g.) Octane for 3dsMax 3.08.1 - 5.1 on your master and Octane Standalone 3.08.1 on your slaves.
Posted: Wed Jun 06, 2018 10:41 am
by asile
thanks a lot ) !
So...it work with one of the network slaves. But i cant start the daemon slave on the others (a quick window error say something like invalid path, invalid name..)
i rebooted many times but slave doesnt want to start. There s no error on install daemon . i tried with 3.07 version, same problem...
Posted: Wed Jun 06, 2018 12:09 pm
by paride4331
Hi asile,
did you check all daemon version?
Could you share a screenshot about your issue?
Posted: Wed Jun 06, 2018 1:43 pm
by asile
All daemon version are good , i cleaned all before reinstall.
I had lot of difficulty to "screenshot" the windows cause it appear during 1/10 sec lol . so here 2 jpg ..
I tested again and again..... So, when i installed and reinstalled again and again, maybe 10 times, and miracle, sometimes the daemon started good.
its totaly random !.... so, i m scary about reboot the daemon computer lol, im not sure the slave will start normaly..
Posted: Thu Jun 07, 2018 8:02 am
by paride4331
Hi asile,
I think you incorrectly configured daemon while installing it.
you should uninstall daemon using _uninstall_daemon.bat in Octane folder and make sure daemon is no longer in startup applications when you run windows.
Then reinstall everything giving ok all answers as default.
Did you set up with an out-of-core option?
Is bitdefender antivirus installed?
