failed to start plugin server OCTANE_Light
Posted: Wed May 23, 2018 12:54 pm
by roentgen
Hi I'm using lightwave2018.0 and octane3.08.0.10
Pressing "Add Octane Light" to put a light, I've got an error message that's in the title.
Can I fix this?
best,
00:00:00 (0000.00) | Log started Wed May 23 21:39:02 2018
00:00:00 (0000.00) | Octane Render for Lightwave by Juanjo Gonz疝ez. Build 3.08.0.10 (Build date: Apr 24 2018 01:49:20)
00:00:00 (0000.08) | Octane API: 3.08
00:00:00 (0000.08) | System: GenuineIntel Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz, 4012 Mhz., 8 cores
00:00:00 (0000.08) | OS: Windows 8 64-bit
GeForceGTX 1080 driver version 23.21.13.8813
Windows10
Re: failed to start plugin server OCTANE_Light
Posted: Wed May 23, 2018 7:44 pm
by juanjgon
What version of LW2018 are you using? Be aware that the plugin only works fine with the 2018.0.3 and 2018.0.4 LW builds. If this is not the problem, it can be an installation issue. Can you please add the plugin .p file to the layout after removing the Octane master plugin?
Posted: Thu May 24, 2018 6:39 pm
by roentgen
Thanks for your replying,
My LW2018's version is "2018.0 (Build 3063) (Win64) 13-Jan-2018".
I'm going to try newer, later.
Posted: Thu May 24, 2018 6:55 pm
by roentgen
Now I try to add OCTANE_Light on LW2018 2018.0.4 then it works fine.
I had missed dot-release updater!
Thanks for your help!
