Crash when using instance
Posted: Sat Apr 28, 2018 4:09 am
by coresign
I get the error message when I create an instance node, and once I click reload button Houdini crashed.
Re: Crash when using instance
Posted: Sat Apr 28, 2018 6:19 pm
by juanjgon
Do you have the object(s) to be instanced enabled? Currently, the plugin can't instance objects that are not enabled in the scene. If you need to hide these master objects from the rendering, you have an option in the Octane spare parameters to hide them, but they must be enabled or the plugin is not going to be able to extract them.
In any case, the plugin should never crash. I'll try to reproduce this problem here, but can you please attach your scene to be sure that I'm testing the same problem?
Posted: Sat Apr 28, 2018 11:56 pm
by coresign
I upload a gif file ,it's just happen when IPR window opened
Posted: Sun Apr 29, 2018 4:47 pm
by juanjgon
Ah, Ok. So this is an IPR only issue adding the instance node, right? Yes, I can reproduce this problem here. I'll fix it for the next build.
Posted: Mon Apr 30, 2018 12:38 am
by coresign
Yes ,only happen when ipr window is opened, thanks you
Posted: Sun May 20, 2018 7:58 pm
by juanjgon
I've fixed this issue for the next build.
Thanks for reporting it!
