Render failure. Triangle count is over the limit?
Posted: Sun Apr 08, 2018 9:36 am
Hey guys,
I've been working on this scene like crazy, and when I finally put all the elements together, Octane won't render it. In the Live Viewer, it says :
Now I've started reading on this error, and it seems like the triangle count limit was increased to >70m triangle count for VR 3.0, yet it still stops at 19m?
I have 16 Gigs of RAM and 8GB of VRAM (GTX1080.
Here's the output in the console window :
Thank you so much for your time. Really appreciate it.
I'm on VR 3.07-R2.Render Failure!!! Check Console window and Octane log window. triangle count:19.41m can be high. Try to decrease polygon counts.
Is there anything that stands out? Is my only option to reduce the triangle count, or to render in different parts?Started logging on 08.04.18 04:52:34
OctaneVR 3.07 (3070007)
shader error...
shader error...
Create Materials....
shader error...
shader error...
Tried to access pin via an invalid ID P_DIFFUSE (30)
Tried to access null node pin
Export materials time= 11686.272 ms
Collect objects time= 39.169 ms
Mesh creation time = 6173.369 ms.
MB:0/0 ST/MOV:0/1022 Nodes:2241 Tris:0 DispTris:0 Hairs:0 Meshes:0
VRAM used/free/max:273Mb/4.618Gb/8Gb Out-of-core used:0Kb total used RAM:15.318Gb
Total export Time = 19007.838 ms
Out-of-core memory limit exceeded
<<< Render failure detected!!! >>>
Please check render statistics to solve the problem.
MB:0/0 ST/MOV:0/1022 Nodes:2241 Tris:19.752m DispTris:22k Hairs:0 Meshes:1k
Device:0 TotMem:8Gb rtData:262Mb film:11Mb geo:3.193Gb node:56Kb tex:1.13Gb unavailable:2.89Gb temperature:53
