Blender 15.1
Posted: Tue Apr 03, 2018 1:49 pm
by aufwind
thanks for the update.
I really appreciate that object / shader visibility status is now taken into account before compiling.
It works great when the objects are hidden in outliner.
When the objects are hidden via the blender layer system the speed improvement is much less. Could this be improved?
Because hiding objects on layers is faster and more versatile.
With linked objects from other blend files it doesn't work.
Probably renaming of the transmission Pin breaks compatability with older blendfiles (nodes are detached).
Images look different compared to Version 14 (I've tried various settings without success)
Blender Version 14
Blender Version 15.1
I don't like the new system without a dedicated preview imager node, because when you're not rendering through
a camera, you have to select the active camera to be able to make any changes to the imager node.
Re: Blender 15.1
Posted: Tue Apr 03, 2018 2:06 pm
by Dmi3ryd
Just opened the old project and crash. It's stable. :oops:
Re: Blender 15.1
Posted: Tue Apr 03, 2018 2:20 pm
by J.C
Looks like Camera images is off. I've noticed that previous projects opened in 15.1 Camera imager is off.
Re: Blender 15.1
Posted: Tue Apr 03, 2018 3:00 pm
by Dmi3ryd
I disabled the function and everything worked fine. Thanks J.C
Re: Blender 15.1
Posted: Fri Apr 06, 2018 9:28 am
by aufwind
J.C wrote:Looks like Camera images is off. I've noticed that previous projects opened in 15.1 Camera imager is off.
Tested both with diabled and enabled. Haven't tried yet with RAW Settings in the colormanagement settings though.
Re: Blender 15.1
Posted: Fri Apr 06, 2018 9:46 am
by aufwind
I've been comparing compilation time between 3.07 and 3.08 RC3 further more with a complex scene.
Compilation until render starts (all Objects visible) 3.07 and 3.08 RC3 around 55s.
95% of Geometry hidden inOutliner Compilation Time 3.07: 25s, 3.08 RC3: 9s (yeah!!)
95% of Geometry hidden with Blender Layer System Compilation Time 3.07 and 3.08 RC3 25s.
As mentioned above it would be great if the compilation time reduction would work in conjunction with
the Blender Layer System.
Re: Blender 15.1
Posted: Thu Apr 12, 2018 3:38 am
by DrawFun
Hi aufwind,
Thanks for your suggestions.
It will be introduced in 15.2.
Cheers,
DrawFun
