Version 14, imager and general render issue
Posted: Mon Apr 02, 2018 2:52 am
I was needing to use the imager to remove some hot pixels and it didn't work like I was thinking it should. It would work ok in the view port, but when used in the final render the image would become over exposed. I have attached some examples of the issue. Also when I exported a ORBX file from Blender and rendered it with 3.08 standalone again (even with the imager turned off) the Blender plugin render comes out with a higher exposure than standalone. There might have been some fixes between the versions, or I could be missing a setting somewhere? The render speed is much faster with 3.08, 2min vs 6min on 3.07.
Jason
Version 14, Blender plugin, imager turned on Version 14, Blender plugin, imager turned off Version 3.08 Standalone, imager on and hot pixel removal (from ORBX file)
Jason
