HDRS NOT LOADING WHEN THEY ARE ON SYSTEM DISK
Posted: Wed Mar 07, 2018 5:23 pm
by sauloarruda
Hi All,
In my computer I have one ssd disk for system, and a second one for backup. In the ssd disk I keep also my HDRs library. I open a scene That I was working, and the Hdr was not loading.
So I tried to replicate the problem. I am using LW 2018 and the last version of octane.
I made some printscreens to demonstrate the problem. If someone is going to test the scene remember to CUT the hdr from system disk to local disk, or vice versa. If you just get the file and move, It will make a copy.
In previous versions, This was not happening.
Saulo
Re: HDRS NOT LOADING WHEN THEY ARE ON SYSTEM DISK
Posted: Wed Mar 07, 2018 5:25 pm
by sauloarruda
The printscreen sequence correct is upwards.
Posted: Wed Mar 07, 2018 10:19 pm
by juanjgon
Hmm, what a weird issue. What is the full path of the texture file in your system disk? Perhaps it has some kind of not supported international character or something like that.
If you enable the Octane log file in the plugin options panel, after rendering the failed texture perhaps an error message related to this issue could be reported on it. You can attach the log file here to check it.
Posted: Thu Mar 08, 2018 12:24 am
by sauloarruda
Hi Juanjo,
I am attaching the two logs. When the HDR is in the system disk you will see this message in the log:
00:00:00 (0000.35) | Evaluating render target nodal editor
00:00:00 (0000.35) | + Processing the ThinLensCamera node
00:00:00 (0000.35) | + Processing the TextureEnvironment node
00:00:00 (0000.35) | --> Procesing a new ImageTexture node
00:00:00 (0000.35) | --> Filename: C:\Users\Usuário\Desktop\bokubarake.hdr
00:00:00 (0000.35) * OCTANE API MSG: Could not load 'C:\Users\Usuário\Desktop\bokubarake.hdr:rgba'.
It take some time to figure out what was hapening. It is very weird because before everthing was fine.
Posted: Thu Mar 08, 2018 12:26 am
by sauloarruda
00:00:00 (0000.00) | Log started Wed Mar 7 21:04:21 2018
00:00:00 (0000.00) | Octane Render for Lightwave by Juanjo González. Build 3.08.0.7 (Build date: Mar 5 2018 10:49:07)
00:00:00 (0000.08) | Octane API: 3.08 RC 1
00:00:00 (0000.08) | System: GenuineIntel Intel(R) Core(TM) i7-7800X CPU @ 3.50GHz, 3495 Mhz., 12 cores
00:00:00 (0000.08) | OS: Windows 8 64-bit
00:00:00 (0000.08) | Init rendering from frame 0 to 0 step 1
00:00:00 (0000.08) | Range rendering disabled for F9 still images
00:00:00 (0000.08) | Init preview window
00:00:00 (0000.09) | >>> Draw preview window progress bar
00:00:00 (0000.09) | Enter inside the main rendering function
00:00:00 (0000.09) | Render layers disabled
00:00:00 (0000.09) | ()() RENDERING FRAME 0
00:00:00 (0000.09) | ()()() Evaluating scene for frame 0
00:00:00 (0000.09) | Init scene
00:00:00 (0000.09) | >>> Refresh preview window
00:00:00 (0000.10) | >>> Refresh preview window done
00:00:00 (0000.10) | Init the root geometryGroup
00:00:00 (0000.10) | Processing the motion blur data
00:00:00 (0000.10) | Get the scene motion blur settings
00:00:00 (0000.10) | Motion blur disabled, computing only one time sample
00:00:00 (0000.10) | Processing time sample 1 of 1, time: 0.000000
00:00:00 (0000.10) | Get camera motion blur data
00:00:00 (0000.10) | * position: -0.016223 0.069557 2.332527
00:00:00 (0000.10) | * target: -0.016223 0.069557 -97.667473
00:00:00 (0000.10) | * fov: 45.239731
00:00:00 (0000.10) | Get Objects motion blur data
00:00:00 (0000.10) | Object dragon diffuse transformation matrix:
00:00:00 (0000.10) | -0.490904 0.000000 -0.871214 0.000000
00:00:00 (0000.10) | 0.000000 1.000000 0.000000 0.000000
00:00:00 (0000.10) | 0.871214 -0.000000 -0.490904 -0.000000
00:00:00 (0000.10) | Get vertex deformations motion blur data
00:00:00 (0000.10) | Get Lights motion blur data
00:00:00 (0000.10) | Light Light transformation matrix:
00:00:00 (0000.10) | 0.707107 0.405580 -0.579228 -2.000000
00:00:00 (0000.10) | 0.000000 0.819152 0.573576 2.000000
00:00:00 (0000.10) | 0.707107 -0.405580 0.579228 2.000000
00:00:00 (0000.10) | Motion blur data ready
00:00:00 (0000.10) | Processing objects list from LW scene. FIRST PASS
00:00:00 (0000.10) | Number of LW objects: 1
00:00:00 (0000.10) | -> Reading scene UV Maps list
00:00:00 (0000.10) | --> Detected 0 UVMaps in scene
00:00:00 (0000.10) | Processing object: 10000000, name: dragon diffuse
00:00:00 (0000.10) | Object dragon diffuse is a LW object without clones, we must add the mesh to Octane database
00:00:00 (0000.10) | Searching if FiberFX is available in this object
00:00:00 (0000.10) | >>> Processing the number of valid polygons
00:00:00 (0000.10) | >>> This object has 87130 of 87130 valid polygons
00:00:00 (0000.11) | >>> Draw preview window progress bar
00:00:00 (0000.11) | >>> Refresh preview window done
00:00:00 (0000.11) | >>> Adding a new mesh to Octane
00:00:00 (0000.11) | >>> Mesh points: 43512, valid polygons: 87130
00:00:00 (0000.11) | ----> Searching UV maps in this object
00:00:00 (0000.11) | ----> No UV maps found in this object
00:00:00 (0000.11) | [profile] Function "LWOctane_getVMap" over "" execution time: 0.000 seconds
00:00:00 (0000.11) | >>> Processing vertex per poly array
00:00:00 (0000.11) | [profile] Function "LWOctane_getVertsPerPoly" over "" execution time: 0.005 seconds
00:00:00 (0000.11) | >>> Processing vertex list
00:00:00 (0000.11) | [profile] Function "LWOctane_addVertex" over "" execution time: 0.001 seconds
00:00:00 (0000.12) | +++ Searching object materials
00:00:00 (0000.12) | +++ Found 1 materials inside dragon diffuse
00:00:00 (0000.12) | +++ Material 0 ID: Default
00:00:00 (0000.12) | +++ Searching in the object materials for UVMAP nodes
00:00:00 (0000.12) | >>> Searching UVMAP node inside surface Default
00:00:00 (0000.12) | >>> This material doesn't have a valid UVMAP node
00:00:00 (0000.12) | >>> Processing polygon data
00:00:00 (0000.33) | [profile] Function "LWOctane_addPolData" over "" execution time: 0.211 seconds
00:00:00 (0000.33) | >>> Mesh added, evaluating it
00:00:00 (0000.33) | [profile] Function "LWOctane_addMesh" over "" execution time: 0.223 seconds
00:00:00 (0000.33) | >>> Refresh preview window
00:00:00 (0000.33) | >>> Draw preview window progress bar
00:00:00 (0000.33) | >>> Refresh preview window done
00:00:00 (0000.33) | +++ Processing object materials
00:00:00 (0000.33) | > Filtering 1 materials in 87130 polygons
00:00:00 (0000.33) | > Filtering 1 materials in 0 hairs
00:00:00 (0000.33) | Used materials in this object: 1
00:00:00 (0000.33) | +++ Processing material Default
00:00:00 (0000.33) | +++ WARNING: This material doesn't have a valid Octane material node
00:00:00 (0000.33) | +++ This material only has a basic parameters, not active node editor
00:00:00 (0000.33) | +++ Basic parameters added
00:00:00 (0000.33) | +++ End of materials processing
00:00:00 (0000.33) | Searching FiberFX hair materials
00:00:00 (0000.33) | +++ Processing object layer maps functions
00:00:00 (0000.33) | --> Get object global dissolve value: 0.000000, state 0
00:00:00 (0000.33) | [profile] Function "LWOctane_addGeom" over "dragon diffuse" execution time: 0.232 seconds
00:00:00 (0000.33) | Processing objects list from LW scene. SECOND PASS
00:00:00 (0000.33) | Second pass check for object 10000000
00:00:00 (0000.33) | Object dragon diffuse has the native Lightwave instancer plugin with 0 instances
00:00:00 (0000.33) | Processing instances ...
00:00:00 (0000.33) | Second pass check for object 10000000 ok.
00:00:00 (0000.33) | Setting the objects geometry group to the scene root geometry group, index 0
00:00:00 (0000.33) | Setting the instances geometry group to the scene root geometry group, index 2
00:00:00 (0000.33) | -> Releasing scene UV Maps list
00:00:00 (0000.33) | Objects processing end ok
00:00:00 (0000.33) | Processing Octane lights from LW scene.
00:00:00 (0000.33) | Number of LW lighs in scene: 1
00:00:00 (0000.33) | Reading light info - name: Light
00:00:00 (0000.33) | Light Light, type distant, not supported by Octante currently
00:00:00 (0000.33) | Setting the lights geometry group to the scene root geometry group, index 1
00:00:00 (0000.33) | Lights processing end ok
00:00:00 (0000.33) | Init the renderTarget
00:00:00 (0000.33) | Setting the root geometryGroup to the renderTarget
00:00:00 (0000.33) | Setting the default render target nodes
00:00:00 (0000.33) | Evaluating render target nodal editor
00:00:00 (0000.33) | + Processing the ThinLensCamera node
00:00:00 (0000.33) | + Processing the TextureEnvironment node
00:00:00 (0000.33) | --> Procesing a new ImageTexture node
00:00:00 (0000.33) | --> Filename: E:\jobs_2018\dragon\bokubarake.hdr
00:00:00 (0000.34) | + Processing the Imager node
00:00:00 (0000.34) | + Processing the PathTracing node
00:00:00 (0000.34) | + Processing the RenderPasses node
00:00:00 (0000.34) | Render target nodal editor evaluated succesfully
00:00:00 (0000.34) | Get or update scene camera
00:00:00 (0000.34) | Camera type is THINLENS_CAMERA
00:00:00 (0000.34) | Removing the old camera motion blur data
00:00:00 (0000.34) | Removing the old objects motion blur data
00:00:00 (0000.34) | Removing the old objects deformations motion blur data
00:00:00 (0000.34) | Removing the old lights motion blur data
00:00:00 (0000.34) | Scene loaded
00:00:00 (0000.34) | Render resolution: 640 x 480
00:00:00 (0000.34) | ()()() RENDERING ...
00:00:00 (0000.34) | ... set image callback ...
00:00:00 (0000.34) | Render scene, set renderTarget and update
00:00:00 (0000.34) | >>> Refresh preview window
00:00:00 (0000.34) | >>> Draw preview window progress bar
00:00:00 (0000.34) | >>> Refresh preview window done
00:00:00 (0000.34) | ... first update
00:00:00 (0000.34) | ... setRenderPriority
00:00:00 (0000.34) | ... RenderPriority set to 0
00:00:00 (0000.34) | ... set Motion Blur parameters
00:00:00 (0000.34) | ... setRenderTargetNode
00:00:00 (0000.70) | ... second update
00:00:00 (0000.70) | ... isRenderingPaused
00:00:00 (0000.70) | >>> Refresh preview window
00:00:00 (0000.70) | >>> Draw preview window progress bar
00:00:00 (0000.70) | >>> Refresh preview window done
00:00:00 (0000.70) | Render setup Ok.
00:00:00 (0000.70) | [profile] Function "LWOctane_renderScene" over "" execution time: 0.359 seconds
00:00:00 (0000.70) | <> Mem Used/Free/Total: 451 / 8823 / 11264
00:00:00 (0000.70) | <> Triangles/DisplaceTris/Hairs/Objects/Voxels rendered: 87130 / 0 / 0 / 1 / 0
00:00:00 (0000.70) | <> Textures RGB32/RGB64/GREY8/GREY16 used: 0 / 1 / 0 / 0
00:00:00 (0000.70) | ... Init rendering ...
00:00:00 (0000.83) | >>> processing image callback
00:00:00 (0000.83) | Reading preview image
00:00:00 (0000.83) | ... Get sampling information
00:00:00 (0000.83) | ... Statistics: 1 of 1000 samples, 0 sec, 7.72 Ms/sec
00:00:00 (0000.83) | ... Get buffers resolution
00:00:00 (0000.83) | ... Resolution: 640 480
00:00:00 (0000.83) | ... Check compositing
00:00:00 (0000.83) | ... Compositing 0
00:00:00 (0000.83) | ... Reading frame buffer
00:00:01 (0001.15) | Reading preview image successfully
00:00:01 (0001.15) | [profile] Function "GetPreviewImage" over "" execution time: 0.318 seconds
00:00:01 (0001.15) | >>> Refresh preview window
00:00:01 (0001.15) | >>> Refresh preview window done
00:00:01 (0001.15) | >>> processing image callback
00:00:01 (0001.15) | ... Get sampling information
00:00:01 (0001.15) | ... Statistics: 32 of 1000 samples, 0 sec, 34.14 Ms/sec
00:00:01 (0001.15) | ... Get buffers resolution
00:00:01 (0001.15) | ... Resolution: 640 480
00:00:01 (0001.15) | ... Check compositing
00:00:01 (0001.15) | ... Compositing 0
00:00:01 (0001.15) | ... Reading frame buffer
00:00:01 (0001.16) | >>> Draw preview window information
00:00:01 (0001.16) | >>> Draw preview window status
00:00:01 (0001.16) | >>> Draw preview window progress bar
00:00:01 (0001.16) | >>> Draw preview image
00:00:01 (0001.16) | >>> Draw preview image finished. Releaseing mutex
00:00:01 (0001.50) | Reading preview image successfully
00:00:01 (0001.50) | [profile] Function "GetPreviewImage" over "" execution time: 0.349 seconds
00:00:01 (0001.50) | >>> Refresh preview window
00:00:01 (0001.50) | >>> Refresh preview window done
00:00:01 (0001.50) | >>> processing image callback
00:00:01 (0001.50) | ... Get sampling information
00:00:01 (0001.50) | ... Statistics: 144 of 1000 samples, 0 sec, 64.80 Ms/sec
00:00:01 (0001.50) | ... Get buffers resolution
00:00:01 (0001.50) | ... Resolution: 640 480
00:00:01 (0001.50) | ... Check compositing
00:00:01 (0001.50) | ... Compositing 0
00:00:01 (0001.50) | ... Reading frame buffer
00:00:01 (0001.51) | >>> Draw preview window information
00:00:01 (0001.51) | >>> Draw preview window status
00:00:01 (0001.51) | >>> Draw preview window progress bar
00:00:01 (0001.51) | >>> Draw preview image
00:00:01 (0001.51) | >>> Draw preview image finished. Releaseing mutex
00:00:01 (0001.83) | Reading preview image successfully
00:00:01 (0001.83) | [profile] Function "GetPreviewImage" over "" execution time: 0.331 seconds
00:00:01 (0001.83) | >>> Refresh preview window
00:00:01 (0001.83) | >>> Refresh preview window done
00:00:01 (0001.83) | >>> processing image callback
00:00:01 (0001.83) | ... Get sampling information
00:00:01 (0001.83) | ... Statistics: 256 of 1000 samples, 1 sec, 76.99 Ms/sec
00:00:01 (0001.83) | ... Get buffers resolution
00:00:01 (0001.83) | ... Resolution: 640 480
00:00:01 (0001.83) | ... Check compositing
00:00:01 (0001.83) | ... Compositing 0
00:00:01 (0001.83) | ... Reading frame buffer
00:00:01 (0001.84) | >>> Draw preview window information
00:00:01 (0001.84) | >>> Draw preview window status
00:00:01 (0001.84) | >>> Draw preview window progress bar
00:00:01 (0001.84) | >>> Draw preview image
00:00:01 (0001.84) | >>> Draw preview image finished. Releaseing mutex
00:00:02 (0002.17) | Reading preview image successfully
00:00:02 (0002.17) | [profile] Function "GetPreviewImage" over "" execution time: 0.338 seconds
00:00:02 (0002.17) | >>> Refresh preview window
00:00:02 (0002.17) | >>> Refresh preview window done
00:00:02 (0002.17) | >>> processing image callback
00:00:02 (0002.17) | ... Get sampling information
00:00:02 (0002.17) | ... Statistics: 384 of 1000 samples, 1 sec, 85.43 Ms/sec
00:00:02 (0002.17) | ... Get buffers resolution
00:00:02 (0002.17) | ... Resolution: 640 480
00:00:02 (0002.17) | ... Check compositing
00:00:02 (0002.17) | ... Compositing 0
00:00:02 (0002.17) | ... Reading frame buffer
00:00:02 (0002.18) | >>> Draw preview window information
00:00:02 (0002.19) | >>> Draw preview window status
00:00:02 (0002.19) | >>> Draw preview window progress bar
00:00:02 (0002.19) | >>> Draw preview image
00:00:02 (0002.19) | >>> Draw preview image finished. Releaseing mutex
00:00:02 (0002.49) | Reading preview image successfully
00:00:02 (0002.49) | [profile] Function "GetPreviewImage" over "" execution time: 0.327 seconds
00:00:02 (0002.49) | >>> Refresh preview window
00:00:02 (0002.49) | >>> Refresh preview window done
00:00:02 (0002.49) | >>> processing image callback
00:00:02 (0002.49) | ... Get sampling information
00:00:02 (0002.49) | ... Statistics: 480 of 1000 samples, 1 sec, 86.61 Ms/sec
00:00:02 (0002.49) | ... Get buffers resolution
00:00:02 (0002.49) | ... Resolution: 640 480
00:00:02 (0002.49) | ... Check compositing
00:00:02 (0002.49) | ... Compositing 0
00:00:02 (0002.49) | ... Reading frame buffer
00:00:02 (0002.51) | >>> Draw preview window information
00:00:02 (0002.51) | >>> Draw preview window status
00:00:02 (0002.51) | >>> Draw preview window progress bar
00:00:02 (0002.51) | >>> Draw preview image
00:00:02 (0002.51) | >>> Draw preview image finished. Releaseing mutex
00:00:02 (0002.85) | Reading preview image successfully
00:00:02 (0002.85) | [profile] Function "GetPreviewImage" over "" execution time: 0.352 seconds
00:00:02 (0002.85) | >>> Refresh preview window
00:00:02 (0002.85) | >>> Refresh preview window done
00:00:02 (0002.86) | >>> Draw preview window information
00:00:02 (0002.86) | >>> Draw preview window status
00:00:02 (0002.86) | >>> Draw preview window progress bar
00:00:02 (0002.86) | >>> Draw preview image
00:00:02 (0002.86) | >>> Draw preview image finished. Releaseing mutex
00:00:02 (0002.91) | >>> processing image callback
00:00:02 (0002.91) | Reading preview image
00:00:02 (0002.91) | ... Get sampling information
00:00:02 (0002.91) | ... Statistics: 624 of 1000 samples, 2 sec, 90.23 Ms/sec
00:00:02 (0002.91) | ... Get buffers resolution
00:00:02 (0002.91) | ... Resolution: 640 480
00:00:02 (0002.91) | ... Check compositing
00:00:02 (0002.91) | ... Compositing 0
00:00:02 (0002.91) | ... Reading frame buffer
00:00:03 (0003.26) | Reading preview image successfully
00:00:03 (0003.26) | [profile] Function "GetPreviewImage" over "" execution time: 0.350 seconds
00:00:03 (0003.26) | >>> Refresh preview window
00:00:03 (0003.26) | >>> Refresh preview window done
00:00:03 (0003.27) | >>> Draw preview window information
00:00:03 (0003.27) | >>> Draw preview window status
00:00:03 (0003.27) | >>> Draw preview window progress bar
00:00:03 (0003.27) | >>> Draw preview image
00:00:03 (0003.27) | >>> Draw preview image finished. Releaseing mutex
00:00:03 (0003.76) | >>> processing image callback
00:00:03 (0003.76) | Reading preview image
00:00:03 (0003.76) | ... Get sampling information
00:00:03 (0003.76) | ... Statistics: 912 of 1000 samples, 2 sec, 94.42 Ms/sec
00:00:03 (0003.76) | ... Get buffers resolution
00:00:03 (0003.76) | ... Resolution: 640 480
00:00:03 (0003.76) | ... Check compositing
00:00:03 (0003.76) | ... Compositing 0
00:00:03 (0003.76) | ... Reading frame buffer
00:00:04 (0004.00) | ... Finish Rendering ...
00:00:04 (0004.00) | ... wait for the getPreviewImage function ...
00:00:04 (0004.08) | Reading preview image successfully
00:00:04 (0004.08) | [profile] Function "GetPreviewImage" over "" execution time: 0.323 seconds
00:00:04 (0004.08) | >>> Refresh preview window
00:00:04 (0004.08) | >>> Refresh preview window done
00:00:04 (0004.08) | >>> processing image callback
00:00:04 (0004.08) | ... Get sampling information
00:00:04 (0004.08) | ... Statistics: 1000 of 1000 samples, 3 sec, 0.00 Ms/sec
00:00:04 (0004.08) | ... Get buffers resolution
00:00:04 (0004.08) | ... Resolution: 640 480
00:00:04 (0004.08) | ... Check compositing
00:00:04 (0004.08) | ... Compositing 0
00:00:04 (0004.08) | ... Reading frame buffer
00:00:04 (0004.41) | Reading preview image successfully
00:00:04 (0004.41) | [profile] Function "GetPreviewImage" over "" execution time: 0.329 seconds
00:00:04 (0004.41) | >>> Refresh preview window
00:00:04 (0004.41) | >>> Refresh preview window done
00:00:04 (0004.50) | ... reset image callback ...
00:00:04 (0004.50) | >>> Draw preview window information
00:00:04 (0004.50) | >>> Draw preview window status
00:00:04 (0004.50) | >>> Draw preview window progress bar
00:00:04 (0004.50) | >>> Draw preview image
00:00:04 (0004.50) | >>> Draw preview image finished. Releaseing mutex
00:00:04 (0004.50) | Reading final HDRI image
00:00:04 (0004.50) | ... Lock HDRI render buffers
00:00:04 (0004.60) | ... Buffers ready, film size: 640 x 480, buffer size: 640 x 480
00:00:04 (0004.60) | ... Composite state: 0
00:00:04 (0004.60) | ... Image read ok
00:00:04 (0004.60) | Image read successfully
00:00:04 (0004.60) | [profile] Function "GetImage" over "" execution time: 0.101 seconds
00:00:04 (0004.60) | ()()() Rendering done
00:00:04 (0004.67) | <> FRAME 0 done, render time 3 seconds
00:00:04 (0004.67) | <> Mem Used/Free/Total: 451 / 8827 / 11264
00:00:04 (0004.67) | <> Triangles/DisplaceTris/Hairs/Objects/Voxels rendered: 87130 / 0 / 0 / 1 / 0
00:00:04 (0004.67) | <> Textures RGB32/RGB64/GREY8/GREY16 used: 0 / 1 / 0 / 0
00:00:04 (0004.67) | Close and free scene, free buffer: 0, reset scene: 1
00:00:04 (0004.67) | ... setRenderTargetNode(NULL)
00:00:04 (0004.69) | ... update()
00:00:04 (0004.69) | ... getRootNodeGraph()->clear()
00:00:04 (0004.69) | >>> Refresh preview window
00:00:04 (0004.69) | >>> Draw preview window progress bar
00:00:04 (0004.74) | >>> Refresh preview window done
00:00:04 (0004.74) | Scene closed
00:00:04 (0004.74) | Close preview window
00:00:04 (0004.74) | Octane Render for Lightwave, end of log system
Posted: Thu Mar 08, 2018 12:28 am
by juanjgon
Yep, I think that the problem is the "Usuário" string, perhaps it is not supported now by Octane, or there is a problem in LightWave to process this international character. LightWave had problems with this kind of characters before ...
Posted: Thu Mar 08, 2018 12:29 am
by sauloarruda
00:00:00 (0000.00) | Log started Wed Mar 7 21:10:21 2018
00:00:00 (0000.08) | System: GenuineIntel Intel(R) Core(TM) i7-7800X CPU @ 3.50GHz, 3492 Mhz., 12 cores
00:00:00 (0000.09) | >>> Draw preview window information
00:00:00 (0000.09) | >>> Draw preview window status
00:00:00 (0000.09) | >>> Draw preview image
00:00:00 (0000.09) | >>> Draw preview image finished. Releaseing mutex
00:00:00 (0000.10) | >>> Draw preview image finished. Releaseing mutex
00:00:00 (0000.11) | Init the root geometryGroup
00:00:00 (0000.11) | Processing the motion blur data
00:00:00 (0000.11) | Get the scene motion blur settings
00:00:00 (0000.11) | Motion blur disabled, computing only one time sample
00:00:00 (0000.11) | Processing time sample 1 of 1, time: 0.000000
00:00:00 (0000.11) | Get camera motion blur data
00:00:00 (0000.11) | * position: -0.016223 0.069557 2.332527
00:00:00 (0000.11) | * target: -0.016223 0.069557 -97.667473
00:00:00 (0000.11) | * fov: 45.239731
00:00:00 (0000.11) | Get Objects motion blur data
00:00:00 (0000.11) | Object dragon diffuse transformation matrix:
00:00:00 (0000.11) | -0.490904 0.000000 -0.871214 0.000000
00:00:00 (0000.11) | 0.000000 1.000000 0.000000 0.000000
00:00:00 (0000.11) | 0.871214 -0.000000 -0.490904 -0.000000
00:00:00 (0000.11) | Get vertex deformations motion blur data
00:00:00 (0000.11) | Get Lights motion blur data
00:00:00 (0000.11) | Light Light transformation matrix:
00:00:00 (0000.11) | 0.707107 0.405580 -0.579228 -2.000000
00:00:00 (0000.11) | 0.000000 0.819152 0.573576 2.000000
00:00:00 (0000.11) | 0.707107 -0.405580 0.579228 2.000000
00:00:00 (0000.11) | Motion blur data ready
00:00:00 (0000.11) | Processing objects list from LW scene. FIRST PASS
00:00:00 (0000.11) | Number of LW objects: 1
00:00:00 (0000.11) | -> Reading scene UV Maps list
00:00:00 (0000.11) | --> Detected 0 UVMaps in scene
00:00:00 (0000.11) | Processing object: 10000000, name: dragon diffuse
00:00:00 (0000.11) | Object dragon diffuse is a LW object without clones, we must add the mesh to Octane database
00:00:00 (0000.11) | Searching if FiberFX is available in this object
00:00:00 (0000.11) | >>> Processing the number of valid polygons
00:00:00 (0000.12) | >>> This object has 87130 of 87130 valid polygons
00:00:00 (0000.12) | >>> Refresh preview window
00:00:00 (0000.12) | >>> Draw preview window information
00:00:00 (0000.12) | >>> Draw preview window status
00:00:00 (0000.12) | >>> Draw preview window progress bar
00:00:00 (0000.12) | >>> Draw preview image
00:00:00 (0000.12) | >>> Draw preview image finished. Releaseing mutex
00:00:00 (0000.12) | >>> Refresh preview window done
00:00:00 (0000.12) | >>> Adding a new mesh to Octane
00:00:00 (0000.12) | >>> Mesh points: 43512, valid polygons: 87130
00:00:00 (0000.12) | ----> Searching UV maps in this object
00:00:00 (0000.12) | ----> No UV maps found in this object
00:00:00 (0000.12) | [profile] Function "LWOctane_getVMap" over "" execution time: 0.001 seconds
00:00:00 (0000.12) | >>> Processing vertex per poly array
00:00:00 (0000.14) | [profile] Function "LWOctane_getVertsPerPoly" over "" execution time: 0.016 seconds
00:00:00 (0000.14) | >>> Processing vertex list
00:00:00 (0000.14) | [profile] Function "LWOctane_addVertex" over "" execution time: 0.003 seconds
00:00:00 (0000.14) | +++ Searching object materials
00:00:00 (0000.14) | +++ Found 1 materials inside dragon diffuse
00:00:00 (0000.14) | +++ Material 0 ID: Default
00:00:00 (0000.14) | +++ Searching in the object materials for UVMAP nodes
00:00:00 (0000.14) | >>> Searching UVMAP node inside surface Default
00:00:00 (0000.14) | >>> This material doesn't have a valid UVMAP node
00:00:00 (0000.14) | >>> Processing polygon data
00:00:00 (0000.35) | [profile] Function "LWOctane_addPolData" over "" execution time: 0.202 seconds
00:00:00 (0000.35) | >>> Mesh added, evaluating it
00:00:00 (0000.35) | [profile] Function "LWOctane_addMesh" over "" execution time: 0.227 seconds
00:00:00 (0000.35) | >>> Refresh preview window
00:00:00 (0000.35) | >>> Draw preview window information
00:00:00 (0000.35) | >>> Draw preview window status
00:00:00 (0000.35) | >>> Draw preview window progress bar
00:00:00 (0000.35) | >>> Draw preview image
00:00:00 (0000.35) | >>> Draw preview image finished. Releaseing mutex
00:00:00 (0000.35) | >>> Refresh preview window done
00:00:00 (0000.35) | +++ Processing object materials
00:00:00 (0000.35) | > Filtering 1 materials in 87130 polygons
00:00:00 (0000.35) | > Filtering 1 materials in 0 hairs
00:00:00 (0000.35) | Used materials in this object: 1
00:00:00 (0000.35) | +++ Processing material Default
00:00:00 (0000.35) | +++ WARNING: This material doesn't have a valid Octane material node
00:00:00 (0000.35) | +++ This material only has a basic parameters, not active node editor
00:00:00 (0000.35) | +++ Basic parameters added
00:00:00 (0000.35) | +++ End of materials processing
00:00:00 (0000.35) | Searching FiberFX hair materials
00:00:00 (0000.35) | +++ Processing object layer maps functions
00:00:00 (0000.35) | --> Get object global dissolve value: 0.000000, state 0
00:00:00 (0000.35) | [profile] Function "LWOctane_addGeom" over "dragon diffuse" execution time: 0.244 seconds
00:00:00 (0000.35) | Processing objects list from LW scene. SECOND PASS
00:00:00 (0000.35) | Second pass check for object 10000000
00:00:00 (0000.35) | Object dragon diffuse has the native Lightwave instancer plugin with 0 instances
00:00:00 (0000.35) | Processing instances ...
00:00:00 (0000.35) | Second pass check for object 10000000 ok.
00:00:00 (0000.35) | Setting the objects geometry group to the scene root geometry group, index 0
00:00:00 (0000.35) | Setting the instances geometry group to the scene root geometry group, index 2
00:00:00 (0000.35) | -> Releasing scene UV Maps list
00:00:00 (0000.35) | Objects processing end ok
00:00:00 (0000.35) | Processing Octane lights from LW scene.
00:00:00 (0000.35) | Number of LW lighs in scene: 1
00:00:00 (0000.35) | Reading light info - name: Light
00:00:00 (0000.35) | Light Light, type distant, not supported by Octante currently
00:00:00 (0000.35) | Setting the lights geometry group to the scene root geometry group, index 1
00:00:00 (0000.35) | Lights processing end ok
00:00:00 (0000.35) | Init the renderTarget
00:00:00 (0000.35) | Setting the root geometryGroup to the renderTarget
00:00:00 (0000.35) | Setting the default render target nodes
00:00:00 (0000.35) | + Processing the Imager node
00:00:00 (0000.35) | + Processing the PathTracing node
00:00:00 (0000.35) | + Processing the RenderPasses node
00:00:00 (0000.35) | Render target nodal editor evaluated succesfully
00:00:00 (0000.35) | Get or update scene camera
00:00:00 (0000.35) | Camera type is THINLENS_CAMERA
00:00:00 (0000.35) | Removing the old camera motion blur data
00:00:00 (0000.35) | Removing the old objects motion blur data
00:00:00 (0000.35) | Removing the old objects deformations motion blur data
00:00:00 (0000.35) | Removing the old lights motion blur data
00:00:00 (0000.35) | Scene loaded
00:00:00 (0000.35) | Render resolution: 640 x 480
00:00:00 (0000.35) | ()()() RENDERING ...
00:00:00 (0000.35) | ... set image callback ...
00:00:00 (0000.35) | Render scene, set renderTarget and update
00:00:00 (0000.36) | >>> Draw preview image finished. Releaseing mutex
00:00:00 (0000.36) | >>> Refresh preview window done
00:00:00 (0000.36) | ... first update
00:00:00 (0000.36) | ... setRenderPriority
00:00:00 (0000.36) | ... RenderPriority set to 0
00:00:00 (0000.36) | ... set Motion Blur parameters
00:00:00 (0000.36) | ... setRenderTargetNode
00:00:00 (0000.73) | ... second update
00:00:00 (0000.73) | ... isRenderingPaused
00:00:00 (0000.73) | >>> Refresh preview window
00:00:00 (0000.73) | >>> Draw preview window progress bar
00:00:00 (0000.73) | >>> Refresh preview window done
00:00:00 (0000.73) | Render setup Ok.
00:00:00 (0000.73) | [profile] Function "LWOctane_renderScene" over "" execution time: 0.382 seconds
00:00:00 (0000.73) | <> Mem Used/Free/Total: 0 / 9287 / 11264
00:00:00 (0000.73) | <> Triangles/DisplaceTris/Hairs/Objects/Voxels rendered: 87130 / 0 / 0 / 1 / 0
00:00:00 (0000.73) | <> Textures RGB32/RGB64/GREY8/GREY16 used: 0 / 0 / 0 / 0
00:00:00 (0000.73) | ... Init rendering ...
00:00:01 (0001.33) | >>> processing image callback
00:00:01 (0001.33) | Reading preview image
00:00:01 (0001.33) | ... Get sampling information
00:00:01 (0001.33) | ... Statistics: 1 of 1000 samples, 0 sec, 0.80 Ms/sec
00:00:01 (0001.33) | ... Get buffers resolution
00:00:01 (0001.33) | ... Resolution: 640 480
00:00:01 (0001.33) | ... Check compositing
00:00:01 (0001.33) | ... Compositing 0
00:00:01 (0001.33) | ... Reading frame buffer
00:00:01 (0001.66) | Reading preview image successfully
00:00:01 (0001.66) | [profile] Function "GetPreviewImage" over "" execution time: 0.330 seconds
00:00:01 (0001.66) | >>> Refresh preview window
00:00:01 (0001.66) | >>> Refresh preview window done
00:00:01 (0001.66) | >>> processing image callback
00:00:01 (0001.66) | ... Get sampling information
00:00:01 (0001.66) | ... Statistics: 32 of 1000 samples, 0 sec, 14.04 Ms/sec
00:00:01 (0001.66) | ... Get buffers resolution
00:00:01 (0001.66) | ... Resolution: 640 480
00:00:01 (0001.66) | ... Check compositing
00:00:01 (0001.66) | ... Compositing 0
00:00:01 (0001.66) | ... Reading frame buffer
00:00:01 (0001.66) | >>> Draw preview window information
00:00:01 (0001.67) | >>> Draw preview window status
00:00:01 (0001.67) | >>> Draw preview window progress bar
00:00:01 (0001.67) | >>> Draw preview image
00:00:01 (0001.67) | >>> Draw preview image finished. Releaseing mutex
00:00:01 (0001.98) | Reading preview image successfully
00:00:01 (0001.98) | [profile] Function "GetPreviewImage" over "" execution time: 0.322 seconds
00:00:01 (0001.98) | >>> Refresh preview window
00:00:01 (0001.98) | >>> Refresh preview window done
00:00:01 (0001.98) | >>> processing image callback
00:00:01 (0001.98) | ... Get sampling information
00:00:01 (0001.98) | ... Statistics: 128 of 1000 samples, 0 sec, 37.23 Ms/sec
00:00:01 (0001.98) | ... Get buffers resolution
00:00:01 (0001.98) | ... Resolution: 640 480
00:00:01 (0001.98) | ... Check compositing
00:00:01 (0001.98) | ... Compositing 0
00:00:01 (0001.98) | ... Reading frame buffer
00:00:01 (0001.99) | >>> Draw preview window information
00:00:01 (0001.99) | >>> Draw preview window status
00:00:01 (0001.99) | >>> Draw preview window progress bar
00:00:01 (0001.99) | >>> Draw preview image
00:00:01 (0001.99) | >>> Draw preview image finished. Releaseing mutex
00:00:02 (0002.32) | Reading preview image successfully
00:00:02 (0002.32) | [profile] Function "GetPreviewImage" over "" execution time: 0.338 seconds
00:00:02 (0002.32) | >>> Refresh preview window
00:00:02 (0002.32) | >>> Refresh preview window done
00:00:02 (0002.32) | >>> processing image callback
00:00:02 (0002.32) | ... Get sampling information
00:00:02 (0002.32) | ... Statistics: 240 of 1000 samples, 1 sec, 53.41 Ms/sec
00:00:02 (0002.32) | ... Get buffers resolution
00:00:02 (0002.32) | ... Resolution: 640 480
00:00:02 (0002.32) | ... Check compositing
00:00:02 (0002.32) | ... Compositing 0
00:00:02 (0002.32) | ... Reading frame buffer
00:00:02 (0002.32) | >>> Draw preview window information
00:00:02 (0002.32) | >>> Draw preview window status
00:00:02 (0002.32) | >>> Draw preview window progress bar
00:00:02 (0002.33) | >>> Draw preview image
00:00:02 (0002.33) | >>> Draw preview image finished. Releaseing mutex
00:00:02 (0002.65) | Reading preview image successfully
00:00:02 (0002.65) | [profile] Function "GetPreviewImage" over "" execution time: 0.327 seconds
00:00:02 (0002.65) | >>> Refresh preview window
00:00:02 (0002.65) | >>> Refresh preview window done
00:00:02 (0002.65) | >>> processing image callback
00:00:02 (0002.65) | ... Get sampling information
00:00:02 (0002.65) | ... Statistics: 352 of 1000 samples, 1 sec, 63.20 Ms/sec
00:00:02 (0002.65) | ... Get buffers resolution
00:00:02 (0002.65) | ... Resolution: 640 480
00:00:02 (0002.65) | ... Check compositing
00:00:02 (0002.65) | ... Compositing 0
00:00:02 (0002.65) | ... Reading frame buffer
00:00:02 (0002.65) | >>> Draw preview window information
00:00:02 (0002.65) | >>> Draw preview window status
00:00:02 (0002.65) | >>> Draw preview window progress bar
00:00:02 (0002.65) | >>> Draw preview image
00:00:02 (0002.65) | >>> Draw preview image finished. Releaseing mutex
00:00:03 (0003.01) | Reading preview image successfully
00:00:03 (0003.01) | [profile] Function "GetPreviewImage" over "" execution time: 0.360 seconds
00:00:03 (0003.01) | >>> Refresh preview window
00:00:03 (0003.01) | >>> Refresh preview window done
00:00:03 (0003.01) | >>> processing image callback
00:00:03 (0003.01) | ... Get sampling information
00:00:03 (0003.01) | ... Statistics: 480 of 1000 samples, 1 sec, 69.47 Ms/sec
00:00:03 (0003.01) | ... Get buffers resolution
00:00:03 (0003.01) | ... Resolution: 640 480
00:00:03 (0003.01) | ... Check compositing
00:00:03 (0003.01) | ... Compositing 0
00:00:03 (0003.01) | ... Reading frame buffer
00:00:03 (0003.02) | >>> Draw preview window information
00:00:03 (0003.02) | >>> Draw preview window status
00:00:03 (0003.02) | >>> Draw preview window progress bar
00:00:03 (0003.02) | >>> Draw preview image
00:00:03 (0003.02) | >>> Draw preview image finished. Releaseing mutex
00:00:03 (0003.35) | Reading preview image successfully
00:00:03 (0003.35) | [profile] Function "GetPreviewImage" over "" execution time: 0.340 seconds
00:00:03 (0003.35) | >>> Refresh preview window
00:00:03 (0003.35) | >>> Refresh preview window done
00:00:03 (0003.35) | >>> processing image callback
00:00:03 (0003.35) | ... Get sampling information
00:00:03 (0003.35) | ... Statistics: 592 of 1000 samples, 2 sec, 74.33 Ms/sec
00:00:03 (0003.35) | ... Get buffers resolution
00:00:03 (0003.35) | ... Resolution: 640 480
00:00:03 (0003.35) | ... Check compositing
00:00:03 (0003.35) | ... Compositing 0
00:00:03 (0003.35) | ... Reading frame buffer
00:00:03 (0003.36) | >>> Draw preview window information
00:00:03 (0003.36) | >>> Draw preview window status
00:00:03 (0003.36) | >>> Draw preview window progress bar
00:00:03 (0003.37) | >>> Draw preview image
00:00:03 (0003.37) | >>> Draw preview image finished. Releaseing mutex
00:00:03 (0003.66) | Reading preview image successfully
00:00:03 (0003.66) | [profile] Function "GetPreviewImage" over "" execution time: 0.314 seconds
00:00:03 (0003.66) | >>> Refresh preview window
00:00:03 (0003.66) | >>> Refresh preview window done
00:00:03 (0003.67) | >>> Draw preview window information
00:00:03 (0003.67) | >>> Draw preview window status
00:00:03 (0003.67) | >>> Draw preview window progress bar
00:00:03 (0003.67) | >>> Draw preview image
00:00:03 (0003.67) | >>> Draw preview image finished. Releaseing mutex
00:00:03 (0003.85) | >>> processing image callback
00:00:03 (0003.85) | Reading preview image
00:00:03 (0003.85) | ... Get sampling information
00:00:03 (0003.85) | ... Statistics: 752 of 1000 samples, 2 sec, 78.94 Ms/sec
00:00:03 (0003.85) | ... Get buffers resolution
00:00:03 (0003.85) | ... Resolution: 640 480
00:00:03 (0003.85) | ... Check compositing
00:00:03 (0003.85) | ... Compositing 0
00:00:03 (0003.85) | ... Reading frame buffer
00:00:04 (0004.18) | Reading preview image successfully
00:00:04 (0004.18) | [profile] Function "GetPreviewImage" over "" execution time: 0.327 seconds
00:00:04 (0004.18) | >>> Refresh preview window
00:00:04 (0004.18) | >>> Refresh preview window done
00:00:04 (0004.19) | >>> Draw preview window information
00:00:04 (0004.19) | >>> Draw preview window status
00:00:04 (0004.19) | >>> Draw preview window progress bar
00:00:04 (0004.19) | >>> Draw preview image
00:00:04 (0004.19) | >>> Draw preview image finished. Releaseing mutex
00:00:04 (0004.55) | >>> processing image callback
00:00:04 (0004.55) | Reading preview image
00:00:04 (0004.55) | ... Get sampling information
00:00:04 (0004.55) | ... Statistics: 1000 of 1000 samples, 3 sec, 0.00 Ms/sec
00:00:04 (0004.55) | ... Get buffers resolution
00:00:04 (0004.55) | ... Resolution: 640 480
00:00:04 (0004.55) | ... Check compositing
00:00:04 (0004.55) | ... Compositing 0
00:00:04 (0004.55) | ... Reading frame buffer
00:00:04 (0004.55) | ... Finish Rendering ...
00:00:04 (0004.55) | ... wait for the getPreviewImage function ...
00:00:04 (0004.84) | Reading preview image successfully
00:00:04 (0004.84) | [profile] Function "GetPreviewImage" over "" execution time: 0.290 seconds
00:00:04 (0004.84) | >>> Refresh preview window
00:00:04 (0004.84) | >>> Refresh preview window done
00:00:04 (0004.85) | ... reset image callback ...
00:00:04 (0004.85) | >>> Draw preview window information
00:00:04 (0004.85) | >>> Draw preview window status
00:00:04 (0004.85) | >>> Draw preview window progress bar
00:00:04 (0004.85) | >>> Draw preview image
00:00:04 (0004.86) | >>> Draw preview image finished. Releaseing mutex
00:00:04 (0004.86) | Reading final HDRI image
00:00:04 (0004.86) | ... Lock HDRI render buffers
00:00:04 (0004.95) | ... Buffers ready, film size: 640 x 480, buffer size: 640 x 480
00:00:04 (0004.95) | ... Composite state: 0
00:00:04 (0004.95) | ... Image read ok
00:00:04 (0004.95) | Image read successfully
00:00:04 (0004.95) | [profile] Function "GetImage" over "" execution time: 0.098 seconds
00:00:04 (0004.95) | ()()() Rendering done
00:00:04 (0004.98) | <> FRAME 0 done, render time 4 seconds
00:00:04 (0004.98) | <> Mem Used/Free/Total: 450 / 8826 / 11264
00:00:04 (0004.98) | <> Triangles/DisplaceTris/Hairs/Objects/Voxels rendered: 87130 / 0 / 0 / 1 / 0
00:00:04 (0004.98) | <> Textures RGB32/RGB64/GREY8/GREY16 used: 0 / 0 / 0 / 0
00:00:04 (0004.98) | Close and free scene, free buffer: 0, reset scene: 1
00:00:04 (0004.98) | ... setRenderTargetNode(NULL)
00:00:04 (0004.99) | ... update()
00:00:04 (0004.99) | ... getRootNodeGraph()->clear()
00:00:04 (0004.99) | >>> Refresh preview window
00:00:04 (0005.00) | >>> Draw preview window progress bar
00:00:05 (0005.00) | >>> Refresh preview window done
00:00:05 (0005.00) | Scene closed
00:00:05 (0005.00) | Close preview window
00:00:05 (0005.01) |
00:00:05 (0005.01) | Octane Render for Lightwave, end of log system
Posted: Thu Mar 08, 2018 10:19 am
by sauloarruda
Hi Juanjo,
I aam from Brazil, and my windows is Portuguese. But I moved my textures to the backup disk, and now I wont have problems. Thanks for your feedback.
Posted: Thu Mar 08, 2018 11:33 am
by juanjgon
Yes, I'm afraid that there is a problem with these international characters. You are going to need to avoid them in the texture paths.
