Workaround for reflection on pure white floor
Posted: Thu Feb 22, 2018 10:20 pm
by Lubo
Hello,
can someone tell me, how to get a reflection on a pure white floor? I`ve render my scene as an exr File with separate reflection pass, and it works very well, but not on a white floor. I think that it`s not "realistic" but my customer want it :-)
Best regards
Lubo
Re: Workaround for reflection on pure white floor
Posted: Thu Feb 22, 2018 11:24 pm
by niestudio
It should just work with a white glossy material.
What kind of setup do you have?
Posted: Fri Feb 23, 2018 7:10 am
by Lubo
Thank you for your reply.
Sorry, I didn`t have explain it very well.
My setup is similar to yours. But as you can see in the new screenshot it don`t works in the post. If you want to change the "strange" of the reflection with the opac value you see the darker plane of the diffuse layer.
When you masked out the cube the reflection disappears on the pure white enviroment layer.
So what I really nead is a reflection layer with alpha channel as you can see in this vid https://vimeo.com/119848103 on 08:52
I try to rebuild his setup but I can`t. I think the vid is too old.
Posted: Fri Feb 23, 2018 10:40 am
by bepeg4d
Hi Lubo,
please have a look at the Render Layer Passes documentation:
Render Layer Passes
ciao Beppe
