xref crash due to octane?
Posted: Fri Jan 12, 2018 10:49 pm
by coilbook
Hi Paride,
can you check and see if you can xref this file. Seems like my max 2018.4 crashes and autodesk said it works maybe because they don't have octane.
If you can also select those three objects and click merge it crashes max
Re: xref crash due to octane?
Posted: Mon Jan 15, 2018 12:06 pm
by paride4331
Hi coilbook,
I do not know if I correctly understood what you said, but xref merge seems to work well without crashing your carrots.
I attached a clip about this.
Posted: Mon Jan 15, 2018 3:33 pm
by coilbook
paride4331 wrote:Hi coilbook,
Hi Paride
can you do xref object and not xref scene. The scene works fine for us too but xref object crashes max Thanks
Posted: Tue Jan 16, 2018 8:51 am
by paride4331
Hi coilbook,
I tested your scene in xref object and yes, it crashes, but I tested other files without any crashes.
I think this crash depends on material applied to carrots.
changing it, no issue happens.
Posted: Tue Jan 16, 2018 4:37 pm
by coilbook
Thanks. Maybe it is vray problem
