C4D freezes when using octane
Posted: Mon Nov 06, 2017 5:49 pm
by barrge50
Hello,
Recently my C4D just freezes, no bug report, usually when I select the settings gear icon, or opening a octane texture to edit it. I'm working on some simple test scenes with few polygons or less and animated textures so nothing demanding. I have to force close it via Task manger but then C4D wont restart, it gets stuck initializing layout on the C4D loading window. I've check windows is updated and my graphic cards. I was using Octane 3.07 test 6, then I tried the newer 3.07 v2 but still does it. Any ideas?
A. Win 10 16299.19
B. Gtx 1080ti and 970
C. 64gb
D. 388.13
E. 3.07
F. 3.07 v2
G. C4D r19.024
H. Unfortunately as I mentioned I don't get a bug report it just freezes.
George
Re: C4D freezes when using octane
Posted: Mon Nov 06, 2017 10:51 pm
by aoktar
Do you use Creatorz update on win10?
Posted: Mon Dec 11, 2017 1:56 pm
by juan4d
This happens to me
The only way to iniatilize C4D again is to reboot the system.
freezing happens if I rise the diffuse depth option. Leaving it in the default settings works fine.
Posted: Mon Jan 15, 2018 6:14 am
by bphoton
Hi I got exactly the same problem on my PC.. until today i didn't found a solution for this .
Posted: Mon Jan 15, 2018 6:41 am
by aoktar
Could you please record a video to show how it happen?
Posted: Mon Jan 15, 2018 6:52 pm
by bphoton
I'm gonna try yes..
Posted: Thu Jun 07, 2018 7:33 pm
by FAZ
Let me guess... an Asus X99 motherboard with PLX feature? Your problem sounds like mine. If it is, I'd send a bug report ticket to Nvidia so they release a driver that addresses this soon. Octane 3.08 and 4 require cuda 9 which is only contained in the newer drivers.
Posted: Thu Jun 07, 2018 8:03 pm
by aoktar
Please try with 3.08.1-R1
Posted: Wed Nov 10, 2021 1:49 am
by Idonee
I have same problem. Does anyone have a solution?
win 10
Nvidia Geforce RTX 2080 super
Nvidia Geforce GTX 1080
64 gb ram
471.41 studio driver (472.39 gives the same result)
Octane 2021.1 (2020.2.5 gives the same result)
Cinema 4d s 24.11
The game driver solves 90% of the problem and such frustrations become relatively rare (and happen up to 4-5 times a day, instead of 4-5 times per hour)., but in some places it does not work correctly with octane. There is a peculiarity, it hangs up mostly either when calling the node tree or when calling the octane settings. Can you tell me what to do, please?
Posted: Wed Nov 10, 2021 3:43 am
by Idonee
update. I think I found a solution.
I read this thread:
viewtopic.php?f=30&t=73228&start=10
I went to reddit and read the method there, wintab32.dll library I did not give out in the bug report, but it seemed strange that I also recently purchased a Huion tablet, and installed the drivers. So I decided to rename the file.
This solved the problem. I suppose that for some programs will need to change the name back, as for the same tablet Huion. But at least I have that option. I hope this will help someone.
