Octane for Softimage 3.1x
- wireframex
I love Camaro
Main Computer:
Ryzen 3990X / 96Go Ram / 2 x RTX 3090
OS: Windows 11 x64 - NVidia Driver 560.70 - Octane Plugin Build 2023.1.3.141
Licensed: Softimage 2012 SP1 / Lightwave 2024.0.1 / Rhino 8.9
W-Coordinates for strands.
http://vimeo.com/user2509578
Some other improvements...
Added roughness parameter to the diffuse material.
Changed falloff shader to match the standalone one.
Fixed the portal material wich sets the wrong attribute so the material had no effect.
The distributed raytracing parameter of the info channel kernel is changed to the combobox "Sampling Mode"
Materal mix can have a displacement texture.
New polygon side shader included to render backface polygons if the shader is pluged into the opacity port of a material.
The displacement shader will have only a texture input, so you can use the new baking shader or an image shader as input.
Images can be changed at runtime with an external program and will update automaticly.
The alpha inputs of the gradient shader are gone and an issue with the position of the marker is fixed.
Working on the image node. It will be possible to use all image formats, which Softimage can use as image.
It will also possible to uses all image clip effects like crop, flip, rescale, color correct and so on...
face
face
- wireframex
Hey Face,
What do you think about next release for SI ?
Phil
Phil
Main Computer:
- wireframex
Hey Face
Are you still there ?
Phil
Phil
Main Computer:
Yes,
im here. will release a candidate the next time.
face
face
- wireframex
Hey Face,
Any news for SI ?
Any news for SI ?
Main Computer:
- wireframex
Hey Face
Please give us some news ...
Really need to know if you continue the octane dev.
Regards
Phil
Regards
Phil
Main Computer:
